Old 11-12-2008, 08:35 AM
bommimann bommimann is offline
Default AJA IO HD Pro Tools Timecode Problem
Hello from Germany.
please excuse my english. I have a Problem which I try to explain:
After my Media100 Card gave up and I couldn`t get a Replace (to old),
I turned to Final Cut Studio 2 and an AJA IO HD. My main Job is Dubbing so i get my work in different ways. I get Betacam SP, Digibeta, or DV Cam or I have to download an Mpeg 2 File from Clients Server. When i work the old Way with Tape, i capture the Files from Tape with AJA IO HD into Final Cut Pro using the Video Track in a DV PAL Format with 50% Quality (Enough for the Job). For Audio I capture the Original Sound on Channel 1 and the Timecode Signal to Channel 2. I do this on a Mac G5 2,7DP. From there i connect the LTC Timecode from Audio Channel 2 with the LTC Input to Sync IO to let my Pro Tools HD2 Accel (on a Mac G5 2,3DP) run in Slave Mode. This works fine. But when i change Client`s Mpeg 2 into DV Pal and import in in Final Cut Pro to make a Sequenz out of it, I take the Time Code from the Timecode out of the AJA and connect it with the Sync IO. The Display of the Sync IO shows exactly the corect Timecode but the Pro Tools Timeline does not move. (I know, i have to put my Session in Sync Mode) I have checked the incoming Signal on an Audio Mixer and i heard the typical Timecode Noise. I have no explanation for this. To avoid this Problem i would have to Master the Movies to Tape and capture them again the Way I described above, But this is more than four Hours Time for each Movie.
I hope I didn`confuse you, but i found no other way ti describe the Problem
Thank you
Old 11-12-2008, 10:42 AM
TAFF TAFF is offline
Default Re: AJA IO HD Pro Tools Timecode Problem
Have a look in your session setup. In your timecode window check to see if your time code generator settings "Using SYNC" if checked. If it is uncheck it and see if that works.
All the best
Paul McFadden
Supervising Sound Editor
Doctor Who
www.bangpostproduction.com
Old 11-13-2008, 08:28 AM
Thank You Paul,
No, the Generator is not checked. When Sync IO gets a Timecode Signal from Betacam SP, or from Betacam capture to an Audio Track in FCP, it works fine. The Sync IO displays the incoming Timecode and the Timeline runs with the Timcode. When I connect with the AJA IO HD Timecode out, the Display of Sync IO shows the incoming Timecode, but the Timeline remains still. Maybe there is something wrong with the AJA.
Old 11-13-2008, 08:37 AM
minister's Avatar
minister minister is offline
Do you have PT "online"? (command-j)
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
HTML code is On
Timecode chase problem cpunthank Post - Surround - Video 2 09-15-2005 10:56 AM
6.7 Timecode generation problem Richard Barrie Pro Tools TDM Systems (Mac) 4 02-14-2005 08:54 AM
Tempo map and Timecode generating problem Richard Barrie Pro Tools TDM Systems (Mac) 0 06-26-2004 12:36 PM
Timecode problem ... Mr Peete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-24-2001 02:27 AM
overnight timecode problem audiokraftwerk Pro Tools TDM Systems (Mac) 1 03-14-2001 06:51 AM
