Old 12-15-2007, 04:19 PM
Scott Fahy Scott Fahy is offline
Default Faders Sticking PM?
We have been having some issues with faders sticking when switching from bank to bank. Is there a recommended preventative maintenance procedure we should be following to prevent the stickies.
FYI The board is covered when not in use and is inside (not toured) and we have done the reset thing a couple of time prior to sound check
Scott
Old 12-15-2007, 04:40 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Faders Sticking PM?
Hi Scott,
Need a more info to narrow this down...
Which control surface?
Are the faders being touched at the same time the bank is switched? If so, they will be taken offline temporarily (display reads "OFF") until the touch is released, at which point they'll move to the correct position. This is intentional and prevents faders from jumping to the wrong position and/or burning out the fader motor.
There's also a very short time period after the touch is released when this can happen. You can sometimes see this when you switch between banks rapidly, touching faders in between. We're looking to see if this lag time can be shortened, but it's really not an issue for most people.
If it's none of the above then contact Digi Customer Service, and they can walk you through a few other things to check.
Sheldon
Old 12-15-2007, 04:44 PM
Sheldon,
It's the sidecar and no none of the faders are being touched when going from bank to bank. I will contact tech support and have them walk us through it. Tks for the quick response
Scott
Old 12-15-2007, 05:04 PM
Sounds good - keep an eye out for the "touch+release then quick bank" scenario I mentioned, which can cause a similar behavior even when the fader isn't touched. Again, it's rare and you need a pretty fast hand, but it can happen.
Sheldon
Newbee PTLE Digi 003: Faders sticking to 0db position chicken 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 02-21-2009 11:06 PM
003 faders sticking/jumping back to 0 steve mezclador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-15-2008 11:27 AM
003 Sticking Faders?? John Pisciotta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 07-05-2007 12:44 PM
Sticking Faders on Digi002 jazzpermike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-29-2007 05:44 PM
Weird problem with 002 sticking faders Blake Eiseman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-29-2004 10:02 AM
