Tracking in Logic...Mixing in PTools..Possible?
With a Control 24 in front of me, it's hard to even imagine leaving Pro Tools long...I've gotten to love this thing...but I'm interested in the concept of doing all the MIDI in Logic, and cutting the basic tracks of things there and then going to Pro Tools for vocals and mixing.
Does anyone have experience in taking a session started in Logic and somehow getting all those tracks into Pro Tools without headache? Thanks for any input. |
Re: Tracking in Logic...Mixing in PTools..Possible?
Depending on how you use midi, if you give pro tools a chance, you may find that you can use it for all your midi. Otherwise, you can track in Logic and import the tracks to pro tools but the easiest way to do this is to create full length files because Logic does not properly timestamp its audio. Or, you could do your midi in logic then import the midi files into pro tools.
But, why not give pro tools a chance and work with it a little. then if you need notation afterwards you can use something like sibelius. |
btw, you might want to check out the available instruments from eMagic, along with the EXS24 sampler. The integration is amazing...doing software instruments is dead simple with Logic, although I have only used them under OSX so I can't comment on VST behavior. |
I alway use Logic or DP3 to sequence midi and track instrument, then I mix in PT. It's Nothin. I just buss my modules from the console back into audio tracks in Logic, record them, and import them right into PT. Just make sure all of your audio tracks start at the same time. Any other way of doing this would be ridiculous because there is nothing easier.
L-Fire EMO |
If you set bit depth of the FreezeTracks files in Logic to 24 (or 16) instead of 32bit float, you easily export a whole song from Logic > PT . Just copy or rename the FreezeTracks files and import them into a PT session (FreezeTrack files are automatically deleted by Logic when you press the Freeze button again).
But since Freeze (faster than real time) doesn't work on TDM tracks in Logic, you have to move your takes from TDM- to DTDM tracks before you can freeze them this way. |
btw, you might want to check out the available instruments from eMagic, along with the EXS24 sampler. The integration is amazing...doing software instruments is dead simple with Logic, although I have only used them under OSX so I can't comment on VST behavior. <hr /></blockquote><font size="2" face="Verdana, Arial">I don't know what kind of situations you use your systems in but in a professional situation when you're under the gun I would not want to have to deal with the BS timestamping that Logic employs with SD II files. No matter here you think your file is stamped it always is actually stamped at zero. If you try and start a file at bar 1 it will actually have some extra time in front of the start time that you think it's starting at. So unless you start your files at ZERO bars and 1 beat which forces the file to start exactly there you'll an indeterminate amount of audio before the spot that you thought as the start time. A TRUE NIGHTMARE WHICH I HAVE LIVED THROUGH. Logic, although a useful tool is a TOY compared with pro tools. Logic is not ready for prime time not ready for the moments that you have a client breathing down your neck. |
yeah yeah...you're the big pro. We all bow to you. Have you used Logic6? Did you ever do anything more than open up 5.5? Of course not...they are toys.
PT works for you and I"m happy...no really, it makes it much easier for me to sleep at night knowing that you have no LATENCY and aren't saddled with a TOY. But some people might want to play with TOYS like Logic and they deserve getting some accurate information as opposed to rants from a rabid Digi fan who might have used an old version of Logic years back. ymmv. |
I do this all the time, because I need Logis's midi capaibilities and also some other functions like the better tempo resolution. It does take some time to transfer the files for mixing but I think it's worth the pain.
Lion |
Move Sessions from Logic to PTOOLS | tuffy21 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-10-2006 01:49 PM |
Logic 6.4.3 & PTools 6.8.1 fix on Panther 10.3.9 | the tokmeister | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-06-2006 12:25 AM |
syncing a PTools Mac to a Logic mac? | Willie Myers | Pro Tools TDM Systems (Mac) | 1 | 12-09-2004 02:48 AM |
Logic + Ptools LE and software synths | Erik Lutkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-09-2001 08:46 AM |
Need Help with Logic and PTools... | Eugene Hartman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-04-2000 04:52 PM |
