Loss of Audio Output
I have d24 with 24bit 888 and 20bit 882 using PT 4.3.1 Every now and then I loose an audio out! the track plays on the mixer page but nothing shows at the audio interface, no sound or metering. Usually restarting the programme or changing the output assingment solves the problem but it dosen't solve the problem of why!. I have had no response from Digi on this in nearly a year!!!!!!!!!!!! help!...
Re: Loss of Audio Output
I've had the same problem. It seems to happen when I use a lot of plugins and try to add or change voice assignments, bussing, and plugin changes. No help from digi. They did blame it on my plugins.
Good Luck
JLE |
this is a known bug of 4.31 with PT24.
The solution is to downgrade to 4.2 or to upgrade to 5.0. There is also a workaround by keeping 4.31 and only changing its mixer. |
dunno: I got it yesterday on PT5.0.LE on a 001.... Exact same thing: moving ledbars on screen, but no audio.... I reopened the session and it was gone..
For me it was the 24 bit mixer which came with 4.3.1. I trashed this and installed the one that came with 4.2 and the problem never occured again.
rebuilding the desktop worked for me.
I've been getting this same problem when switching inputs 1 -2 to SPDF. Audio craps out although I can see it playing.
G4 MIX Plus 882/20 ATTO dual bus Cheetah 18 gig |
Loss of audio | ktwaudio | Pro Tools 10 | 1 | 11-24-2011 05:30 PM |
Dramatic loss in output volume after running registry scan | Peter Manganay | Windows | 0 | 11-14-2011 04:24 AM |
Loss of Audio | Gazzieh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-27-2009 07:21 AM |
Audio Loss | Pase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-14-2004 09:30 PM |
Loss of audio? | flytrap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-19-2001 06:37 PM |
