Old 07-05-2012, 05:58 PM
sanger sanger is offline
Default Workspace no drives
Hey guys,
Just installed the latest pro tools 10 on windows 7 service pack 1. Everything installed correctly including mbox and eucon artist mix. Pro tools runs flawlessly so im pretty sure the install was all ok.
The problem is workspace browser will not show any drives, i.e. catalogs are there but nothing else.
I can save to any of the 3 local drives on my computer and play back from them no worries. When i bring up the disk space it is recognizes all my drives even external drives and usb sticks and is happy to tell me the remaining audio record time i have left on them all so its not that pro tools isn't seeing the drives. I've also tried with all external hardware removed.
The drives are 2 western digital black drives, a velociraptor, a segate external and various brands of usb thumb drives. All internal drives are formatted in ntfs so im pretty sure i haven't just got unlucky and bought 7 incompatible drives!
I have trashed the prefs a few times but bar doing a full install again (not sure why it would change anything anyway) im fast running out of ideas as to how to get workspace working.
Also forgot to mention the drives im playing back off etc are labelled m: and n: so i dont think that should have anything to do with it.
Thanks in advance for any help you can give.
Old 07-07-2012, 03:27 PM
Zeffener Zeffener is offline
Default Re: Workspace no drives
Hey sanger, I had the same issue after upgrading to PT10. Try choosing "Run as Administrator"
Cheers
Old 07-09-2012, 03:33 AM
Bump for myself!
Just tried to use the trasher http://duc.avid.com/showthread.php?t=316863
But the program cant find the databases. Prefs trashed fine but the data bases cant be found so that could be the root of my problems.
Anyone got any clues???
Old 07-10-2012, 07:05 PM
Cheers
Zeffener you are a genius.
Thanks for taking the time to reply to this message.
Problem solved people. Hope this helps some others as well.
Old 07-26-2012, 02:06 AM
Smiffs Smiffs is offline
Cheers
Hi Zeffener. I was looking for a solution to the same problem...and hey presto!! Thanks alot.
Old 07-26-2012, 02:09 AM
Cheers
Hey Zeffener. I was looking for a solution to the same problem. Hey presto!! Thanks a lot.
Old 08-15-2012, 08:48 AM
Koudio Koudio is offline
Zeffener, HERO!
Old 09-29-2012, 08:30 PM
Injected Senses Injected Senses is offline
Cheers
Life saver! Thanks so much.
Gary Miranda
Injected Senses Productions
Old 12-11-2012, 08:23 AM
bethchampionmason bethchampionmason is offline
Wow, thank you for this info! I've been trying to figure this one out since yesterday. Do you know if there's a way to set "run as administrator" as the default so whenever I open PT it runs that way?
Thanks for the help either way, though!!! I was mystified as to where my drives had gone, and now they're back. :)
Ext Drives not showing up in workspace grumphreys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-20-2013 05:09 PM
Drives not appearing in workspace TheNose14 Windows 1 06-30-2013 07:46 PM
Disabling drives from Workspace Halstein Pro Tools TDM Systems (Mac) 2 11-24-2008 04:33 PM
Excluding drives from the Workspace mattrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-03-2008 01:20 PM
Drives not in workspace Nashville Bass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-21-2005 07:58 AM
