Old 03-06-2011, 05:43 AM
Hotep Hotep is offline
Default how to install Mbox2 LE 7 on Windows 7
OK. I used to have a MAC that I ran my protools LE 7 on. But now I bought a HP laptop with Windows 7 home Premium 64 bit. I installed the Protools LE 6.8.1 installation disk and upgraded it to Protools LE 7 on the HP Lap Top. The problem I am having is that the computer can not find a driver and the computer will not recognize the Mbox. i tried using the compatibility mode for windows xp, but maybe I am not doing it right. Can I use the compatibility mode on on Windows 7 to make this all work. There has got to be way!!!! Can someone help we with this???
Old 03-06-2011, 07:51 AM
albee1952 albee1952 is online now
Default Re: how to install Mbox2 LE 7 on Windows 7
None of that is going to work and you will have to uninstall all of it. Then get PT8 and the 8.0.4 updater. Install 8 on the machine but do NOT connect the Mbox when asked. Just click on OKAY and the install will finish. Reboot and run the 8.0.4 updater and DO connect the Mbox when asked. After another reboot, run the cs 2 updater for 8.0.4(to correct the timing issue) and try to avoid using 48K sample rates(because the timing issue remains on that setting).
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
how can i install mbox2 drivers with ableton and windows 7 32 bit without protools johnchristmas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-06-2011 07:56 AM
Why install Pro-Tools to install drivers for Mbox2 bigbobbysd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2010 07:42 AM
Attempting to install 8.0.4b audio driver for Windows 7 MBox2 j4callen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-27-2010 05:46 PM
Le mbox2 install error SKIPofWELOOSE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-08-2008 04:34 PM
