Old 12-01-2010, 12:23 AM
The Missile Silo The Missile Silo is offline
Question Where is the Disable Fader Movement During Playback feature for Control 24?
I posted this this thread (here it is for reference: http://duc.avid.com/showthread.php?t=287397) in the Control/C|24 forum and the only response I got was for the C|24 - not a Control | 24. After I replied no one else has chimed in - thought I would try here (this forum seems to be a lot more active and budding with information than the other).
Originally Posted by The Missile Silo View Post
Disable Fader Movement During Playback: I have seen it in older versions of PT, but now in 8.0.1cs2 I cannot find it for the life of me! Checked all tabs in the Preferences, the Manuals and nothing.
Has it been removed? Did I just imagine that it ever existed? Is right in front of me somewhere and I'm just over looking it?
Can anyone point me in the right direction for the Control | 24?
Only fader movement on the board - I still want PT to recognize the volume automation during playback ITB.
PS-Sorry DTS Admin if I am posting for the same question/problem in two different forums-just looking for help!
Cheers!
Ron
ron [k]
Musician/Programmer/Engineer/Remixer
System:
PT HD v8.0.1cs2/PT 9 HD3 Accel, 96 I/O, 96i I/O, Control |24, Midi I/O, Sync I/O
___________________________
http://myspace.com/ronk
http://ron-k.net/studio.html
http://facebook.com/ron.k.music
Old 12-01-2010, 12:48 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Where is the Disable Fader Movement During Playback feature for Control 24?
Hi Ron,
There's no feature on the control 24 all you can do is put into master fader made!
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-01-2010, 01:06 AM
Thanks Chris!
Your suggestions is a viable workaround! But I really thought I recalled having seen a check box somewhere in the preferences a few versions ago that would disable such?
Maybe it's the old age of being 31 setting in
Ron
ron [k]
System:
Old 12-01-2010, 07:48 AM
jeremyroberts jeremyroberts is offline
workaround:
Make a bank of EMPTY midi tracks. Set them to faders at 0 (- inf). When you want to playback without any fader movement, bank your control surface to your bank of midi tracks.
Use this technique in conjunction with Massey's "Listen" plugin
--Jeremy
Old 12-01-2010, 08:31 AM
Sean Russell Sean Russell is offline
Default
Good suggestions but I wanted to add that long ago this did exist - DTS told me to use it at a client's who's G4 wouldn't let us bounce a pretty simple pop tune thing. This was 5.3.1, I believe, back in 2003-2004. 001 LE system. Not sure when it disappeared!
... but does it help the chorus?
Old 12-01-2010, 09:22 AM
blairl blairl is offline
There was a preference in the automation preference section for disabling moving faders on the screen. However, this is no longer available. This preference never affected control surface faders.
MP4 Playback Jumpy with image movement Old School Audio Guy Post - Surround - Video 3 01-04-2013 11:00 PM
Where is the Disable Fader Movement...feature? The Missile Silo ICON & C|24 3 12-22-2010 06:48 AM
Control 24 - fader mm movement IntelDoc ICON & C|24 8 07-02-2009 10:06 AM
Fader movement after automation written Siegfried Meier Pro Tools TDM Systems (Mac) 8 01-27-2005 05:24 PM
strange fader movement when recording midi forthecause ProControl, Control|24, Command|8 1 12-18-2004 07:07 PM
