  #31
Old 04-07-2022, 02:54 AM
Sardi Sardi is offline
Default Monterey 12.3.1 Update
I beg to differ. I used Catalina for over a year, and cloned and imaged my boot drive the old way with no problem. "Signed System Volume", which it's called, came with MacOS 11 Big Sur.
I was referring to this.
Since Big Sur, what used to be the boot volume now consists of two volumes; typically called Macintosh HD (which contains the fundamental system files and is locked to any other processes than Apples update installer, basically. The other is then called Macintosh HD - Data, and contains everything else, applications, user files etc. In Finder, they show as one disk, in Disk Utilities you can see that they are two volumes.
That definitely began in Catalina, not Big Sur.
Signed System Volume is indeed a feature added in Big Sur, but the read only system volume which you described above with two seperate volumes appearing as one disk in Finder, was in Catalina.
  #32
Old 04-07-2022, 06:32 AM
daeron80 daeron80 is offline
Default Re: Monterey 12.3.1 Update
It may have been added to Catalina later. I didn't start having trouble with Time Machine backups failing in Catalina due to both disks having the same name until after Big Sur was released. I suspect that they added it to Catalina in an update. Looking forward to my M1 Max coming so I can be done with Catalina. Actually, what I'd like is to go back to Yosemite. It struck the best balance of user-friendliness and configurability for me.
David J. Finnamore
  #33
Old 04-07-2022, 06:57 AM
zoff zoff is offline
So if my my Big Sur computer craps out, I have to install an OS on a different computer and restore from a back up of the Data volume before I can get up and running? Is this correct.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
  #34
Old 04-07-2022, 07:17 AM
No it was definitely there from the start.
I don’t know about Time Machine as I don’t use it, but CCC was able to clone Catalina boot drives on release of the OS.
  #35
Old 04-07-2022, 07:58 AM
Ben Jenssen's Avatar
Yes.
When I got my M1 Mini it had Monterey installed and I wanted to run Bigsur. I knew that the M1 Minis originally shipped with Bigsur, macs today can only be rolled back to what they originally shipped with, so I basically booted from the Recovery, erased the internal, installed from a so-called "USB-installer" w/Bigsur, then used Migration Assistant to transfer everything from backup of my old Catalina Intel Mini. It worked flawlessly, and wasn't very difficult.
  #36
Old 04-07-2022, 11:54 AM
off the wall's Avatar
No issues here with 12.3.1 on my M1|Pro laptop.
offthewallproductions
  #37
Old 04-07-2022, 12:09 PM
audiolex1 audiolex1 is offline
I haven't tried it yet, but this apparently is the 12.3 full installer from Apple.
For those who don't want to install 12.3.1
http://swcdn.apple.com/content/downl...lAssistant.pkg
I got it from here:
https://osxdaily.com/2022/03/14/maco...date-download/
Age old question: what to do about AIR plugins (Monterey update) moshuajusic Pro Tools 3 06-24-2022 10:25 PM
Macros in Monterey thin ice macOS 0 03-11-2022 03:37 AM
Monterey Compatibility ReynaldoPena Pro Tools 33 03-08-2022 07:29 AM
Monterey is now available Obsidian Dragon macOS 80 02-05-2022 10:52 AM
Monterey IOS rjbee Pro Tools | Intro Discussion 1 11-25-2021 10:59 AM
