Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 12-22-2016, 03:44 PM
anothercolour anothercolour is offline
Default How long can I continuously write to a hard drive?
I have decided to back up older audio sessions and files onto one 5TB hard drive. It is going to take approximately 16 hours (firewire to a spinner—non solid state). Do you think it is bad for the drive to write continuously for that long?
Old 12-22-2016, 06:30 PM
Marcel Risberg's Avatar
Marcel Risberg Marcel Risberg is offline
Default Re: How long can I continuously write to a hard drive?
Simple answer: No, it would not be bad for the drive.
It's a bit like asking if it's bad to drive a car for hours. No it is not - but of course I'm assuming now that the car is proberly built and has a working cooling system.
A bit more detailed: So, if your drive is configured and dimensioned correctly, including the external housing, you can have it work for hours without concern. If you are concerned, maybe you looked for a cheap backup drive rather than a high quality build, then you could monitor the heat of the drive by touching it after 20 minutes of use. If it's hot to the touch aim a fan to it to cool it down and make sure it won't degrade faster than normal. If it's not, we'll let it do its thing.
Marcel Risberg
Production sound and audio post - ljuddesign.se
Enthusiastically sharing knowledge and experience at Stockholm Film School.
🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni
🎚 EuControl x.x.x · Artist Control · Mix · Control App
🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019)
📺 Separate video playback machine
🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free
Programmers - How hard can it be to write Driver software? Ormond FireWire & USB Audio Interfaces (Mac) 0 12-06-2015 09:50 AM
Hard drive noise during read write... leftalive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-01-2011 01:08 PM
PT can't auto save write only Hard Disk ( it isnt ) mafiacondon Pro Tools TDM Systems (Mac) 3 02-18-2011 09:04 AM
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Partition Hard Drive? Clean out G$ hard drive? ike805 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 10:23 PM
