Old 05-01-2022, 09:44 AM
virtualG virtualG is offline
Default Need to install Avid Control App 2021.10 for iPad and not latest 2022.4
Is there somewhere on the Avid site I can download Avid control app 2021.10.1.8 installer for iPad and not the default 2022.4 that is now fetched from then Apple App Store. Many thanks
Old 05-01-2022, 12:30 PM
BScout BScout is offline
Default Re: Need to install Avid Control App 2021.10 for iPad and not latest 2022.4
No. You can't roll back the apps.
What you are asking about is side-loading an older version and that's pretty much not allowed by any of the app stores unless you are part of the developer team.
Old 05-06-2022, 09:52 AM
Mixmaster Rick Mixmaster Rick is offline
Default Avid Control App Incompatible
Well my three iPad's which I use with my S1's and Dock have downloaded the latest version of the Control App and are now coming up as incompatible with EuCon.
What do I need to do to get back up and running?
Old 05-06-2022, 09:55 AM
I just encountered the same issue with three iPads. What's the fix?
Old 05-06-2022, 10:08 AM
its2loud its2loud is online now
Originally Posted by Mixmaster Rick View Post
The fix is to install the latest version of EuControl 2022.4 if your tablets have already updated. Turn off auto update on your tables.
Old 05-06-2022, 10:12 AM
Absolutely.
Will EuControl 2022.4 run fine with Pro Tools 2021?
Best
Old 05-06-2022, 10:49 AM
Strike that question - YES it does work fine. Thanks for the guidance!
Old 05-06-2022, 10:53 AM
As you've experienced, it will work fine. However, you will not get some of the feature available until you update to Pro Tools 2022.4.
Old 05-06-2022, 12:13 PM
As always I appreciate your time in helping. Are there any gotchas I should look out for when upgrading to 2022.4? My interfaces are all UAD Apollo x6 and Satellites, large Waves and UAD plugin library...
Best
Avid Icon Control Surface Compatibility (D|Command/Control) with PT Studio 2022.4? Antigua Pro Tools 31 05-19-2022 12:06 AM
MAC M1 PT 2022.4 vs 2021.3.1 videos persen Pro Tools 31 05-04-2022 06:30 PM
Avid control for ipad tonyw7 Avid S1, S3, Dock and Control App 2 01-03-2022 08:26 PM
Avid announces Pro Tools 2020, 2021 and 2022! off the wall Pro Tools 2018 2 04-01-2019 08:50 AM
Anyone using a iPad 3 with the latest version of Pro Tools control? Trainwreckmusic Avid S1, S3, Dock and Control App 6 03-10-2017 04:48 PM
