Alternate use for AD converter: Using pro tools hardware as an EEG machine
so if you are reading this, you probably think i'm crazy. I am an actively recording musician that is working on my doctorate in music performance. I am pursuing a line of questioning about using Electroencephalography to train musicians to deal with performance anxiety. I am doing preliminary research, and would like to run some experiments myself. The question arose on whether a protools rack system can be used to record the electric wave patterns in a subject's scalp.
to simplify this a bit, you place two electrodes near each other on the scalp, and you measure changes in the electric charge of that circuit. The voltage rarely exceeds 1 volt, and the frequencies are from 1-20Hz, basically just under the cutoff of the equipment. for recording purposes, one input can be used as a microphone, and the other 3 amplified inputs could record the signal in great resolution, if the converter identifies it. Some neurologists call the study of EEG readouts "like learning how a car works by sticking your ear on the hood" but I think it might be useful. These wave patterns are not supposed to be reproduced sonically so is the 20Hz a brick wall a hard limit, or can any of you EE majors explain a simple way to have an oscillator at a set frequency (around 2,000 Hz) change it's amplitude to correlate with the 3Hz and .5v signal in the other circuit? |
Re: Alternate use for AD converter: Using pro tools hardware as an EEG machine
i quickly scanned the post
#1, i think you are crazy #2, you state 1-20hz. i dont know of any converters that will translate that low. the cutoff point of the converter is going to be long before 1hz.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
New Machine? New Hardware? Purpose built Machine? | PatriotsBiker | Windows | 4 | 06-29-2013 11:06 PM |
Opcode Timecode machine SMPTE/MIDI converter | Fokke van Saane | Tips & Tricks | 1 | 03-10-2011 05:38 PM |
Help with alternate drum machine system | tobster | General Discussion | 1 | 11-04-2001 10:01 AM |
Serial port converter for Machine Control | Raven | Post - Surround - Video | 1 | 08-08-2000 08:55 AM |
USB To Serial Port Converter for Machine Control | Raven | Pro Tools TDM Systems (Mac) | 0 | 08-07-2000 12:04 AM |
