automation frustration.....
Hey dudes and dude-ettes....
Just getting my legs with PT 8.0.3 right now, finding some automation weirdness. when cutting/separating/moving/importing regions automation data is being written on the outside boundaries of each region. I then have to delete any values I want to change for mixing. Is there a preference to set to disable this behaviour? Also on imported tracks there are automation points written at the session start. Seems like I need to write an automation point and then select all and delete to make it go away. Doesn't work consistently and must be done for all controllers/Channels. Is there a global delete automation command?? Thanks! |
Re: automation frustration.....
yes
edit> clear special> all automation b.o.l. e
ihatetyping |
That's true, just to add: If you use «Import Session Data» to import regions on tracks you can decide if automation should be imported with the track or not. E.g. you can choose to import pan automation but to get rid of volume and mute automation.
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
This usually only happens if 1. you have already written or have an automation breakpoint somewhere which has changed the level of the track!! 2, you have automation follows edit selected in the options menu Chris
Please help me end this frustration | jcolagross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 03-14-2011 07:28 PM |
Frustration! | Herrington | Pro Tools 9 | 3 | 03-01-2011 09:12 AM |
Just a little frustration... Maybe? | Phanxor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 09-29-2007 10:37 AM |
002 for osx frustration | shaun hamontree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-08-2003 12:43 AM |
OMS Frustration !! | Karamella | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-24-2002 04:22 PM |
