Grid vary sporadically and unintentionally
One more amateurish question from the series "Has been disturbing since forever". Please check the attached pics. Is this some kind of anomaly/bug, or is it a result of any action of mine? These ****s appear out of nowhere and seams not to be only a screen/zoom-in problem that is easy solved by changing the zoom level. I don't know if this is purely grid related, or if it could (also) be tempo related somehow. I have several tempo changes in the songs. I don't use any tempo operation windows etc, only the green tempo bar at the top of the screen. Also, I never work in the dedicated Midi Editor window since I hate it, so I work only in the main window, but in Edit mode. The Conductor is "On". Last edited by DigitalVortex; 12-19-2022 at 02:52 PM. |
Re: Grid vary sporadically and unintentionally
Check the Meter ruler. A change from 4/4 to 3/4 will cause a bar to change size. Any meter changes happening?
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
You rule Ben! It absolute solved this old misery. Thanx a lot!
And yes, it emerged that there were a LOT of meter inserts, that I never put there in the first place btw. Strange thing is that all of them were 4/4, so no variation at all. Although, I sense that it's not only about what value you insert, but also where. So if a value is inserted in an "illogical" place – like just in the middle of somewhere – it adds a rhythm data from that very point and in consequence also adds a visual grid data. |
Glad I could help.
Edit Mode difference between: Grid and Slip+Snap to Grid | zenstone | macOS | 0 | 02-05-2015 04:34 AM |
When loop is TCE'd to grid then duplicated out, it doesn't match the grid. | STSCRUSHER | Windows | 1 | 11-23-2012 09:34 AM |
Please help! Signal from Instrument Track appears in Aux/Audio Tracks unintentionally | JimDC | macOS | 2 | 05-07-2012 09:02 AM |
Slip to Grid mode no visual grid unless pressing "grid" | mgoorevich | Pro Tools 9 | 5 | 11-13-2010 07:11 AM |
Link Grid Mode w/Grid display in PT8.0.3? | pugzillas | Pro Tools TDM Systems (Mac) | 7 | 03-19-2010 03:44 PM |
