Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #21
Old 09-28-2022, 06:50 PM
Default Re: MTRX Studio Mic In's / Dolby Audio Bridge...
Originally Posted by LDS View Post
It is happening here even with PTAB 64. I'll give it another spin later today with the unedited config file and see if it performs any better.
Yeah, I tried PTAB 32 and 64, same issue.
https://lukehoward.com/
  #22
Old 09-29-2022, 05:47 AM
creativecontrol's Avatar
Even with PTAB, there's no reason to not use DAB if you are funneling from Pro Tools -> DAPS. It's all set up and ready to go. Use PTAB to get back to Pro Tools and or to route re-renders into Logic for Apple Spatial monitoring on Airpods, etc.
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
  #23
Old 09-29-2022, 07:19 AM
nedd nedd is offline
Jeff
Jeff, would you mind giving some concrete routing to achieve this? Is it possible to listen to speakers and logic (AirPods) at the same time?
___
Mac Studio Ultra, 64GB, 2TB, OS 12.6.3, MTRX Studio, PT Ultimate 22.12, HDX1, Sync HD, BM Decklink Extreme 4K, Dolby Atmos PS, Avid Dock, S1, C|8
  #24
Old 09-29-2022, 07:26 AM
Sure thing.
Jeff
Jeff Komar
S6 FAQ
  #25
Old 09-29-2022, 07:28 AM
Originally Posted by LukeHoward View Post
One more question, PTAB doesn’t do any drift correction/ASRC right? I presume not given you said above everything must be resolved to a common clock, but someone in the Atmos FB group suggested this might be the case.
There was also a question about whether this gets frame accurate sync when using HDX as primary playback engine with Sync genlocked to video ref, but monitoring via renderer patched via Aux I/O.
That was probably me asking about using frame-edge sync with HDX as main playback engine and Aux IO to and from the renderer. I have done some very preliminary testing and lipsync doesn't seem super tight, but I need to do more testing and properly recalibrate with Catching' Sync and their test files multiple times to see if the non-deterministic latency is indeed a problem.
Scott Gatteño
  #26
Old 09-29-2022, 07:30 AM
Both Pro Tools Audio Bridge and Dolby Audio Bridge include an internal synching mechanism which will automatically follow the clock speed of the main playback engine.
best,
Jeff
Jeff Komar
S6 FAQ
  #27
Old 09-29-2022, 07:48 AM
best,
Jeff
Thanks Jeff, that's good to know! It sounds like when using either or both of those paths in Aux IO that at least the latency will be predictable. I am guessing that since those paths are core audio, that they will be subject to latency that is affected by the HW Buffer size. If the Video Offset is calibrated when using those paths, in theory it should be consistent when using a consistent buffer size?
Thanks for answering all these questions! It's definitely helping me wrap my head around these new features.
Scott Gatteño
  #28
Old 09-29-2022, 09:23 AM
Sure thing.
Jeff
Thank you Jeff, this looks like good solution for Laptop set up. I was wondering if there is a way to have renderer connected as usual to the set of speakers and also have a logic at the same time with AirPods Pro?
___
  #29
Old 09-29-2022, 11:09 AM
This described setup is exactly that. Add a 12 channel path (7.1 + 4.0 for heights) in the Input tab of IO setup which leverages AUX IO via PTAB. Output via DigiLink paths to MTRX ST as normal. You can then monitor 7.1.4 speakers, Dolby binaural and Apple Spatial all at once.
Jeff
Jeff Komar
S6 FAQ
  #30
Old 09-29-2022, 11:42 AM
Thanx Jeff, I am still not very clear about this new way of routing signals.
_ I have 9.1.4 set up, does this mean that if I want to monitor thru Logic (as well) I need to send the re-rendered 7.1.4 audio to Logic?
_Normally I have HDX selected in the output of the renderer while DAB is main playback engine. Like this I can open only the renderer and listen to the atmos masters without Pro Tools running, In the way you suggest, will I be able to do it like this as well? Or is PTAB only available while Pro Tools is running?
Looks to me that I need to make some changes in the dadman?
thanks a lot, btw, I am very pleased with the Aux I/O
___
Dolby Renderer sync issue with HDX/MTRX Studio remainanon Pro Tools | MTRX & MTRX Studio 7 05-24-2022 02:32 PM
MTRX Studio HDX and Dolby Atmos Production Suite Goombot Pro Tools | MTRX & MTRX Studio 64 09-30-2021 01:02 AM
What brings Dolby Audio Bridge to HDX users? nedd Post - Surround - Video 29 01-03-2020 03:24 PM
Dolby Audio Bridge and AVB RSLAMBERT Avid S1, S3, Dock and Control App 0 11-03-2019 01:46 PM
Dolby Media Producer Suite v2, Decoder, How to get audio to my SPK w HDX and MTRX rig bsteeve Post - Surround - Video 3 08-16-2019 06:19 AM
