Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 09-28-2022, 03:06 PM
Default Re: MTRX Studio Mic In's / Dolby Audio Bridge...
Originally Posted by creativecontrol View Post
AUX IO in Pro Tools 2022.9 - in combination with DAPS, Bridge and HDX:
https://youtu.be/ZdM3HsHuozQ
Jeff
Looks great!
Can I use Aux I/O to go from Pro Tools to DAPS, but have DAPS connect to a physical MADI interface (connected to and clocked by MTRX)?
https://lukehoward.com/
Old 09-28-2022, 03:45 PM
creativecontrol's Avatar
Yes, you could either use DAB or PTAB to get to DAPS. If PTAB, you would need to make a custom 130 channel path - editing your PTAB config. DAPS could be assigned to any output MADI or Dante for example available to Coreaudio, but definitely clocked.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-28-2022, 04:25 PM
Jeff
Great, look forward to trying when I am not in the middle of something Is there any reason to preference DAB over PTAB in this scenario? I can only think of one, the Atmos Assembler being hard-coded to use DAB, and thus not having to switch input device in DAPS.
Old 09-28-2022, 04:30 PM
One more question, PTAB doesn’t do any drift correction/ASRC right? I presume not given you said above everything must be resolved to a common clock, but someone in the Atmos FB group suggested this might be the case.
There was also a question about whether this gets frame accurate sync when using HDX as primary playback engine with Sync genlocked to video ref, but monitoring via renderer patched via Aux I/O.
Old 09-28-2022, 05:17 PM
LDS LDS is offline
At initial glance, PTAB seems to only support 64 channels while DAB does the full 130 into the renderer.
Old 09-28-2022, 05:27 PM
PTAB can have an arbitrary channel limit, you just need to edit /Library/Audio/Plug-Ins/HAL/ProToolsAudioBridge.driver/Contents/Resources/ProToolsAudioBridge.config.
Code:
# ProToolsAudioBridge configuration file
# Format: WIDTH,NAME
# Add up to 16 lines/devices
2,Pro Tools Audio Bridge 2-A
2,Pro Tools Audio Bridge 2-B
6,Pro Tools Audio Bridge 6
16,Pro Tools Audio Bridge 16
32,Pro Tools Audio Bridge 32
64,Pro Tools Audio Bridge 64
# added for 130 channels similar to DAB
130,Pro Tools Audio Bridge 128+2
Old 09-28-2022, 05:29 PM
LDS LDS is offline
Code:
130,Pro Tools Audio Bridge 130
Gasp! Great tip. Might even rip a few off the list entirely.
Old 09-28-2022, 05:31 PM
My first attempt to get it working wasn't too successful unfortunately, played for a second then no audio received by DAPS. Clearly I'll need to take a day or two in downtime to get it working...
Old 09-28-2022, 05:48 PM
smurfyou smurfyou is offline
Please update if you do! I won't be able to upgrade immediately but it would be nice to know what's possible.
~Will
Old 09-28-2022, 06:05 PM
LDS LDS is offline
It is happening here even with PTAB 64. I'll give it another spin later today with the unedited config file and see if it performs any better.
Dolby Renderer sync issue with HDX/MTRX Studio remainanon Pro Tools | MTRX & MTRX Studio 7 05-24-2022 02:32 PM
MTRX Studio HDX and Dolby Atmos Production Suite Goombot Pro Tools | MTRX & MTRX Studio 64 09-30-2021 01:02 AM
What brings Dolby Audio Bridge to HDX users? nedd Post - Surround - Video 29 01-03-2020 03:24 PM
Dolby Audio Bridge and AVB RSLAMBERT Avid S1, S3, Dock and Control App 0 11-03-2019 01:46 PM
Dolby Media Producer Suite v2, Decoder, How to get audio to my SPK w HDX and MTRX rig bsteeve Post - Surround - Video 3 08-16-2019 06:19 AM
