Old 03-10-2010, 05:49 PM
PhillyMike PhillyMike is offline
Default Pro Tools LE 8.0.3 Audio File Length change upon import / Sample Rate issue
Certain files will be slowed down slightly (about a whole step) whenever I'm batch importing tracks into the session. The Session is set up at 48kHz/24bit, AIFF audio format, Internal Clock Source (003 interface). In the import window, the Destination Sample rate is 48k and the quality is TWEAK HEAD. Running OS X 10.5.8
The files I'm receiving are various sample rates and bit depths (all are AIFF), which I then bring into the session to put them against the QT movie that is in the session.
When they are batch imported a few of them will be fine, but more than half will have slowed down by a whole step and are a few seconds longer in length than the file in the Finder folder where they came from.
If I then try to import only ONE of the files by itself from the same Finder window, in the same manner, then it will be fine.
If I go into the session's Audio Files folder, both the first and second imports are 48k/24bit, but one is slightly larger in size and duration.
Any suggestions/advice?
Sample rate issue, Session was set at 44.1, forgot to change preamp to 44.1, goodfriendelectric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-30-2010 10:19 PM
Select sample rate of audio to import -V7? Karl Engel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-05-2010 10:59 AM
import audio WITHOUT sample rate converting? wwittman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-21-2009 04:25 PM
change sample rate info for audio file djd2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-27-2007 05:19 PM
Altered Sample Rate doesn't Change File Playback?? dbates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-22-2004 04:54 AM
