Avid Scorch
Avid Scorch (iOS) Forum
Scorch Forum Home Page
Forum Terms of Use
Scorch for iPad Support FAQ
Avid Scorch
Go Back   Avid Pro Audio Community > Other Products > Avid Scorch (iOS) Forum
Old 08-27-2013, 11:08 PM
hihat hihat is offline
Default Scorch 1.1, AirTurn and iPad crash
The problem with PDFs is that I cannot transpose them
With the unexpected v1.2 update, I am very slightly optimistic I will be able to use Scorch again.
EDIT: I have tested Airturn with Scorch v1.2 and it seems to work well so far.
Also Airturn have released Digit, a handheld device that works via Bluetooth in the same way, however it is possible to still add on the pedals like the original Airturn unit, so works as either. It has 6 buttons. I have not tested it with Scorch but I presume it would work the same.
Airturn.com
Old 08-28-2013, 04:08 PM
Fraser.Sims Fraser.Sims is offline
Default Re: Scorch 1.1, AirTurn and iPad crash
Yep my airturn also works with 1.2 and iPad 2 which is good news. Still think I will be using forScore a bit longer though, but hopefully Scorch may get the additional features and slightly smother page turns soon when I can then transpose on the fly. So far, no crashes which is encouraging.
Old 08-28-2013, 06:15 PM
For anyone interested, I have tested v1.2 with ipad 1 and Airturn. Turning pages is a little slow and you end up seeing the Desk before the next page loads. If you are reading ahead it should not be much of a problem.
Old 08-29-2013, 12:15 AM
You also briefly see the desktop with an iPad 2 and AirTurn.
Help Avid Scorch App not working with my new Ipad Mixmaster D Avid Scorch (iOS) Forum 1 06-06-2012 05:37 AM
avid scorch for Ipad in the UK itunes store? stinkycats Avid Scorch (iOS) Forum 3 06-06-2012 05:32 AM
Problems with Scorch App on my Ipad and Macbook Air Mixmaster D Avid Scorch (iOS) Forum 0 05-02-2012 02:49 PM
Scorch 1.1 crashes on my iPad 2 smf2914 Avid Scorch (iOS) Forum 4 02-27-2012 06:02 AM
Sibelius 7/Scorch on iPad problem evnoic Avid Scorch (iOS) Forum 10 08-18-2011 04:06 AM
