Avid Scorch
Avid Scorch (iOS) Forum
Scorch Forum Home Page
Forum Terms of Use
Scorch for iPad Support FAQ
Avid Scorch
Go Back   Avid Pro Audio Community > Other Products > Avid Scorch (iOS) Forum
Old 03-06-2012, 11:13 AM
Mikel77 Mikel77 is offline
Default Scorch won't open Sibelius files
I am trying to open files I made in Sibelius on my ipad2 with Scorch.
I emailed the files, opened them and selected Open in Scorch
Scorch opens and I see the file, click on it and click Open and it says 'There was a problem loading the score'
A few opened but there was no play arrow
Old 03-22-2012, 01:44 PM
Fraser.Sims Fraser.Sims is offline
Angry Re: Scorch won't open Sibelius files
Hi Mike, Scorch is very, very, very buggy! Not convinced 1.1 is actually an improvement and wish I could go back to 1.
I find, if a file fails to open, you can click it, and it will usually open the second time. However when you get that error message, the menu bar with play and everything isn't visible and you actually see the initial menu bar with things like store. However, the menu bar is there and you can play by clicking where you know the play button to be! Crazy.
I have reported this as a bug in another thread.
To reset scorch, try closing scorch by double clicking the black square button and when you see all the active icons with a red button, close it. I see someone from Avid is responding to some messages but not most of them. I was hoping that there would be an upgrade but its unlikely as they have our money and we are not important. I think they have a 6 month cycle.
I bought forScore and am now converting my files into pdf. One day scorch may work but until then forScore does most things and I just use Scorch when I need to play back a sib file.
Old 06-26-2012, 02:12 AM
Joe Pearson's Avatar
Joe Pearson Joe Pearson is offline
Super Moderator
Default Re: Scorch won't open Sibelius files
Hello Mikel77,
Which version of Sibelius are you using?
@Fraser.Sims
As I think you've found, the best way of resolving this problem is to restart Scorch. Which version of Sibelius are you using to produce these files? Are you finding that this affects scores that you've purchased from the store too?
Best wishes,
Joe
Old 07-22-2012, 07:29 PM
hihat hihat is offline
Originally Posted by Fraser.Sims View Post
... Scorch is very, very, very buggy!
I have hundreds of lead sheets in what might be v3 Sibelius. They often crash Scorch. Even simple files in v5 can crash it.
Does anyone else have problems with older files?
Old 08-05-2012, 07:19 AM
Hi, most of my scores were created with G7 (sibelius 3?) and they are about 3 pages long. Yes I get random crashes and various other errors. I have upgraded to sibelius7 now principally because G7 doesn't work on lion. However with all the issues with scorch and the delays in getting them fixed, I just use scorch for playing back the files and quick transpositions both of which still work and checking what i have got. Its no use even for practice.
For everything else, I convert the file to PDF (G7 can print to acrobat on windows xp) but Sibelius 7 exports to PDF . I bought forScore for playing as search works and you can easily Create set list and it works with AirTurn.
It's a pain having to convert the files, but at least forScore works, and if a bug is reported, they get a fix out in a few days. Not ideal but as I usually have a few days notice and Sibelius 7 is great for formatting my old scores for the iPad, it's a workable solution. At leas my Sibelius files are getting formatted ready for when scorch is finally upgraded (in 2015?).
Scorch files won't play (sometimes) mdwilkie Avid Scorch (iOS) Forum 0 09-06-2012 06:10 AM
Scorch doesn't work with Safari 5.1. Confirmed by Sibelius! evnoic Avid Scorch (iOS) Forum 4 09-27-2011 02:34 AM
Scorch files purchased from Musicnotes? jgrnt1 Avid Scorch (iOS) Forum 7 08-18-2011 04:11 AM
Sibelius 7/Scorch on iPad problem evnoic Avid Scorch (iOS) Forum 10 08-18-2011 04:06 AM
sibelius and pro tools open at the same time? n8tron General Discussion 0 07-30-2008 10:35 AM
