Re: PT2022.6 Lost Digi Mic Pre
Bizarrely, when I first opened a session in 2022.7 and created a new track with one of the Grace inputs as the track input, the MIC PRE controls did show up for about ten seconds in the Edit Window. I was able to adjust the Gain like normal and toggle the high pass filter and the Grace was responding...and then the controls just disappeared! WTF. I can operate the Grace using its front controls and still get signal into Pro Tools, so it's not quite a paperweight. But less convenient for sure. Can confirm the following is repeatable: If I remove the Grace from Setup/Peripherals (set #1 to "none"), then it gets removed from Setup/IO Setup/Mic Preamps, as you'd expect. If I add the Grace back in Setup/Peripherals (set #1 to "PRE" and choose the midi channels), then add it back to Setup/IO Setup/Mic Preamps, then the controls show up in the Edit Window for a few seconds and then disappear again. So strange. Anyway, won't hold my breath for a fix.
Control Room: PT Ultimate HDX 2023.3.0 // Mac Pro 2012 // Mojave 10.14.6 // BlackMagic DeckLink Intensity Pro // Genelec 5 x 8250A + 7270A DSP Active Subwoofer // Yamaha NS-10's Edit Suite: PT Ultimate 2023.12.1 // Mac Pro 2013 // Monterey 12.7.3 // Focusrite 18i20 // Genelec 5 x 6010A + 5040A Active Subwoofer Video Suite: PT Ultimate 2023.12.1 // iMac Pro 2017 //Monterey 12.7.3 // Focusrite Scarlett Solo |
I just tried 2022.7 and had the same behaviour. The controls appear for a few seconds then disappear if you remove and add the pre
Did you ever find a solution for your Grace Design Pres? I'm having the exact issue with Rednet X2Ps (they break after 2022.5). Its a bit frightening because I have a lot of them and theyre integral to my system. |
Unfortunately, no. I'm running PT 2023.3 now, but MIDI controls for the Grace no longer work unless I stayed on 2022.5.
Pro Tools is showing me this MIDI I/O error every few seconds when I try to add the Grace as a mic PRE. However I've just discovered if I click the "reset" button in the "Peripherals/Mic Preamps" window, it does in fact send a reset command to the Grace! For example if I set a bunch of gain levels using the on-device controls, then click "reset" in Pro Tools, they do get reset on the unit. So obviously the two devices can still communicate (nothing wrong with my MIDI cables), but Avid has somehow changed how the preamp commands work. Frustrating.
Could you let me know what the case # was that you had with support back in late 2022 on this issue. Also the MyAvid email you use would help me find it. I want to dig into this and find out what changed between 2022.5 and now that impacts Grace.... so I can help hellojamison and you out. email me is the best way. Marianna [email protected]
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
Email sent, thank you for looking at this!
FWIW, I’m not having any problem with my RED 8Pre as long as I keep the Rednet Control app open in the background. I set it to launch at boot and minimize it to the dock.
If I were having to troubleshoot the Grace issue, I would start with the MIDI connection.
Ok I found the culprit here. Theres a FB thread on it and I'll post my response to Ben:
I managed to duplicate that message to other channels that were going grey and it fixed the issue. However, PT2023.6 is looking for the message maybe every 10 seconds (more frequently!) so they would go grey for a few secs and then pop back on once the message sent. There is more testing needed, but I'm happy for now as I have all my pres working properly in PT2023.3. Hoping this helps someone. |
Hopefully Avid can come through with a proper fix.
(SOLVED) Re: PT2022.6 Lost Digi Mic Pre
You're all gonna hate me, but the problem was just a bad MIDI cable on the output from my Grace preamp back to my Mac Pro. I've swapped in a known good cable, and now the MIDI controls are working 100%. Even in Pro Tools 2023.6. In all the troubleshooting, I didn't ever try swapping in a new cable...because the old cable was working on Pro Tools v2022.5, even yesterday when I tested it again. But then I hooked up a MIDI keyboard (the good old Roland Juno) with the same cables and sure enough, the Juno couldn't send anything. Swapped in a new cable and boom, back to business. Lesson humbly learned. I can safely say it is not a Pro Tools issue after all. Oh well, what good is the Internet if you can't completely embarrass yourself once in a while...
What Video I/O card after Nitris DX with PT2022.04 on Win10??? | mcfid | Windows | 3 | 10-13-2022 02:21 AM |
Unable to load 003Rack drivers - PT2022, Win. 10 pro | jmaulz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-16-2022 01:41 PM |
Digi 002 Lost connection-Help Please! | Bantom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-31-2012 12:29 PM |
Digi 002 lost connection | Keniko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-19-2005 01:55 PM |
Lost my Digi 001's original box (help, what now)? | Nish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-25-2004 04:37 AM |
