Old 12-19-2010, 12:41 AM
Ransom Ransom is offline
Question Still getting crackling sound with Pro Tools 9
Hi. I tried the 8.0.3 upgrade months ago and gave up with it after not being able to get rid of the crackling sound coming through my mbox2 when my keyboard and speakers were plugged in. Now, I upgrade to Pro Tools 9 which is apparently "fully compatible with windows 7" but I keep getting the crackling sound and can't record anything. What gives?
Old 12-19-2010, 12:51 AM
philip888's Avatar
philip888 philip888 is offline
Default Re: Still getting crackling sound with Pro Tools 9
Can you post a Sandra Report?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 12-19-2010, 01:15 AM
I'm googling how to do that but can't figure out how. Also, I moved the usb that my mbox2 was plugged into and now I'm getting that high pitched whining everyone was getting with 8.0.3 and only when I open Pro Tools 9.
Old 12-19-2010, 08:32 AM
philip888's Avatar
Look you will find it here.
Help us help you - what you need to know before posting!
http://duc.avid.com/showthread.php?t=193637
Old 12-19-2010, 12:40 PM
Thanks for your help Philip, not sure if this helps as well. I found out if I plug my roland phantom keyboard into a power outlet (while it's turned off) the whining noise starts instantly (the phantom is directly plugged into my mbox 2 through two 1/4 inch cables).
I'll post up the sandra soon.
Old 12-20-2010, 07:48 AM
daeron80 daeron80 is offline
That's an electrical issue, not a software one. Something in the analog signal chain prior to the amplifier is acting as an antenna. It's picking up the radio frequency junk that all electronic devices emit. The RFI, as it's called, should get shunted to ground through your cable shields and equipment cases to the ground plug on your electrical outlet, from where it should go to earth. There's a large number of possible reasons why it's not doing that. Bad connection or broken shield in a cable, bad solder joint or loose screw in a piece of gear (mbox, computer, the amplifier itself), and power circuit not properly grounded are the most common. It can also be caused by different gear being plugged into different sockets that are not on the same circuit. Sometimes it can be a real bear trying to track down and solve the problem. I usually start by unplugging everything from everything, reseating all computer cards and loosening and re-tightening all screws on the mobo, test all cables with a meter with jumpers so I can wiggle them during the test, resolder if necessary, and then put it all back together. If that doesn't solve it, you may need a pro electronics repairman.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 12-20-2010, 08:07 AM
getz76 getz76 is offline
daeron80 is right. This sounds like a classic ground loop issue.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 12-20-2010, 01:59 PM
Thanks again for the help everyone, this is driving me nuts!!!!
My question now is, why would I suddenly be getting this signal when I used the exact same setup on my laptop with windows xp and pro tools 7? I've been able to record fine until switching computers and upgrading to PT9. The only changes I've had are new computer (hp elite with windows 7, 64 bit) and new speakers (mackie HR824mk2's). Everything works fine without the phantom plugged in but as soon as I plug it in, problems. Could it be the pc? I'm switching to a brand new imac in a few days, maybe I should just wait and see if the problem crosses over to that.
Old 12-20-2010, 02:14 PM
It could be anything that is connected in the chain. Check your outlets with a ground tester. You can get one at Home Depot for under $10.
I would stop using the setup until you find the issue. It is usually harmless, but occasionally a faulty ground can be deadly.
Old 12-20-2010, 08:03 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Confusing. First it is a crackling sound and now a "whining noise".
You'll have to be more specific.
If everything works until you plug in the Phantom, then it's the Phantom or the cables or the power supply connected to it.
Are you plugging the Phantom into a mic input?
You moved the USB plug and now are getting a totally different sound? That doesn't make sense. Is it to a hub that is plugged into something?
You get the noise even when the Phantom is turned off? Yes, could be a wiring problem with the power. Try plugging everything to one power strip. Also, check that all your power plugs have a ground. Some stupid people cut that off when then have ground loops.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
[IMG] code is Off
Very loud crackling sound WJT2006 macOS 4 07-03-2012 01:11 PM
Crackling sound - Should I go back to 8.0.3? Wings 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-09-2010 10:00 AM
Crackling Pop Sound tomyco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 02-22-2010 06:04 PM
crackling sound during playback dickeycricket 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-19-2003 09:00 PM
crackling sound.... ShuddupBob Digidesign Hardware & Software 2 11-05-2000 09:35 AM
