OSX spaces and PT windows
I need a mac guru advise. I'm wondering if there is a way to assign EDIT window to a space and MIX window to another space and switch between them easily with this OSX feature. It seems it's only possible to switch between app. Is there a script or hack to change this? Thx |
Re: OSX spaces and PT windows
AFAIK it is only possible to assign "whole apps" to different spaces. But I don't understand what you are trying to do. For switching spaces you need keyboard shortcuts or some clicks anyway... so why don't you just use the PT shortcuts to switch between Edit and Mix window?
MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire |
On a slightly different idea.
I have a logitech mx518 gaming mouse and i have serveral shortcuts set up on that for quick workflow and it works really well on mac. Its actually better on mac than xp because on windows you cannot send the Window key as a shortcut which is a pain in the erse. For example this mouse has 7 configurable buttons. ONe switches between mixer and edit... one brings up workspace. two assigned to zoom vertically and then horizontially on selected region. then one to bring it all back down to normal view again. all works very well and for me its very quick |
let's say that u have 2 spaces horizontal, so you are now in the left space with pro tools opened and u see the mix window,
click on the top bar of the mix window, and without to release the click, press CTRL-2, this will make ur mix window go to the 2nd space. but also there is another simplest way, assuming that u are in the left space for example, just grab the mix window from the top and drag it right right on the screen until it goes to the right space then u can switch spaces quickly with ctrl - arrows , or u switch spaces with ctrl-1-2 etc. (if u can't , system prefs -> expose -> spaces -> on bottom is the settings) but also, if u don't use spaces, and u have both Mix and Edit window in 1 monitor opened, u can just press CMD - ` (very nice OSX command that cycles between windows!) peace :) |
I'll try it later today. Cheers, |
@protoolsfanatic: thanks it works.
@johnbhoy: I've ordered the Mx 518 |
hey johnboy,
I'd appreciate some help in setting up the mx 518 mouse. can u pls tell me where you found the drivers for OSX? the original installation disc in only for vista and xp |
I've noticed that certain windows (example system performance) are popout windows and can be moved around. I wish they would do the same for the mix window to be able to move it to another space/monitor.
James Shelby SRS Labs Aurora, Colorado |
QL Spaces out now | JMDNYC | AAX Plug-ins | 1 | 09-25-2013 07:36 AM |
Spaces Crashes | iasandy | Windows | 0 | 01-15-2013 02:19 AM |
PT windows follow me in spaces (transport, memory locations, etc.) | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-29-2010 04:51 PM |
Spaces in Leopard | tsoura | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-17-2008 11:24 AM |
How many rack spaces does the 002 R use? | jazzsounds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 10-03-2003 04:00 PM |
