Old 12-05-2001, 10:19 PM
francona francona is offline
Default Disabling Hard Drive Indexing?
I'm running 9.2.1. Occasionally without warning, the OS decides to update the index my internal hard drive.
I fear the day that this would popup during a critical tracking session. What exactly is this indexing process, and how can I disable it, or at the very least make it a manual process?
Old 12-05-2001, 10:24 PM
carlone carlone is offline
Default Re: Disabling Hard Drive Indexing?
There's an Extention called FBC Indexing Scheduler. If you disable it the mac will stop trying to index.
Old 12-05-2001, 10:30 PM
johnwhynot johnwhynot is offline
Open Sherlock. (command-F in the finder)
In the "Find" menu, select "Index volumes…"
In the little window that opens, there is a list of mounted volumes. Next to each volume name is a check box that applies the schedule to indexing that volume.
Undo all those check marks, close everything, and you'll be bothered by midnite indexing no more.
JW
Old 12-06-2001, 04:06 AM
seandaly seandaly is offline
This feature of Sherlock drove me bats for the first week I had my G4 (recently came over from the PC side), every night at midnight the mysterious reindexer would appear!
Took me a couple of days to figure out the fix (above), it would be helpful I think if Digi reminded new users at install time about this the way they do about virtual drives, AppleTalk, &c
thanks
Old 12-06-2001, 09:47 AM
Doug Ring Doug Ring is offline
..and you DO want to disable it. I lost a lot of material once when the indexer kicked in in the middle of a bounce-to-disk.
While Sherlock does need to index your disks to find files, I've never found it to take so long that I can't wait for the indexer to do its stuff first and then use "find".
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
CIDAEMON.exe and XP Hard drive indexing question bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-23-2005 12:10 PM
Indexing a large SFX drive Brandonx1 Pro Tools TDM Systems (Win) 0 01-07-2005 06:06 PM
How do I stop my hard drive from re-indexing? Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-20-2001 12:45 AM
stop indexing boot drive carloswarlick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-21-2001 12:16 AM
