Re: Pro Tools and M Audio is completely failing me...severe help needed
yes I do have snow leopard, yes i have the pre release, and yes, the elastic time was set to monophonic...but disabling didn't do anything...It appeared to redraw the waveform where the distortion occurred, but no auditorial difference....
Also, I did contact m audio and it took like 2 weeks for them to tell me i just need to get it repaired. I have no idea where my receipt is, but I know for sure that my warranty is long expired....which is sad because it was acting up a little when I first got it...should've fixed it then. Thanks for all the help so far guys....I really appreciate it. If anyone else has any insight or idea please let me know. I am planning on buying the fast track ultra 8r, but that may not be for a long while, as its close to 500 bucks. So until then, I'm still trying to solve this problem, and am extremely open to any other suggestions. |
did you play around with buffer size settings to get the sound right?
Or try to check/uncheck the "ignore RTAS errors" (or similar) in the playback engine...
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Try Recalculating the waveform Data within the Session
Im going to make a copy of this session, and remove all the perfectly fine regions and make it a small file (zip it) and upload it somewhere. If someone downloads this, just let me know if they have the same problem. Like if they listen to the audio files alone and then open it and play it.
I tried recalculating the waveform overviews and it didn't do anything. I haven't dont much with the buffer yet. Funny thing is, i tried consolidating the regions when making this small session to upload, and it actually wrote the distortion/corruption into the audio files in the folder. So i had to redo it without consolidating. This means that it can't be my m-audios fault, because it actually writes the corruption into the audio file if i consolidate the regions with the corruption. But maybe not, because my time machine backed up the sessions when they were good, and when I recover them from there, there still messed up. IDK, this is crazy... Im not sure if this will work or not, im uploading my stuff to mediafire... http://www.mediafire.com/?sharekey=c...4e75f6e8ebb871 or http://uploading.com/files/c389c8am/...2BRemoved.zip/ sorry about the size, I was able to reduce it from 252 mbs to about 30....
2011 21.5 inch iMac 2.5 GHz quad-core intel core i5 16 gigs of ram OS 10.8.4 Pro Tools 10/11 M-Audio Fast Track Ultra 8r BX8A's Tons of software, lots of good mics, tons of storage space |
Please look into your audio files folder if the files are read only...
#16
I hate to be so dependent, but how do I go about doing this? Is it in the get info section? I checked the get info (of the audio files folder) in the shared and permissions and it says I can read and write. The stationary pad isn't checked.
#17
I tried reimporting the audio files and this fixes it, but its not the answer because I absolutely cannot figure how I edited the audio regions. I made so many punch ins and groups and whatnot that even if I reimport them, I can't get them to be the way they were...
#18
Sorry I didn't try this more carefully.
Severe audio glitching issues with MBox 2, makes playback unbearable. | AliGlenUig | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-08-2011 03:39 PM |
Pro Tools keeps Failing | Mach1Entertainment | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-19-2011 01:53 AM |
Failing to launch + Distorted Audio | Hbthyname | Windows | 1 | 02-28-2011 02:09 AM |
Severe audio sync problems Mbox2 Pro | mezza9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-08-2007 05:27 AM |
Import Audio causes PT to completely close | SteveGarman | Pro Tools TDM Systems (Mac) | 2 | 03-07-2006 04:39 PM |
