Strike colours are yellow
Hi All
As the title suggests, I just bought, installed, authorized and registered strike and find when launching within PT, colour is yellow and cannot read \ see anything within plug I remember reading here that xpand used to do this too for some Any ideas very much appreciated as I would like to start using this drum plug asap PT8 3.2 Ghz Mac Pro 10 GB RAM OSX 10.5.6 All plugs updated afaik – does strike now need to be updated? |
Re: Strike colours are yellow
Make sure you've installed the latest update / driver?
http://www.digidesign.com/index.cfm?...&categoryid=36 |
OK, kind of sorted
Applied leopard update, colours are fixed - now launching, but now receive "content not found, please run set content location application" which I've done, defaults to volumes/strike disk 1/set strike content location kind of disheartening after spending alot of dosh on this product and it doesn't even know where to install itself...not to mention the operator surely this occurs with everyone installing strike...? |
OK...this time for sure
All sorted now, applied set content location from apps/digi/strike working now thanks Nubee for your prompt response now i just gotta learn how to use it.... cheers billos |
How were you able to get it to install?
I've tried 3 different methods with no luck. I noticed when it asks for DVD 2 that it puts those files in a completely different directory (using the default method). |
Yellow Strike with ProTools 9 | buckccs | macOS | 5 | 03-17-2011 01:02 PM |
Strike is YELLOW | raydsr | Virtual Instruments | 5 | 02-01-2011 07:31 PM |
Yellow Sreen - Strike | doppler58 | Virtual Instruments | 6 | 05-03-2010 09:10 AM |
Strike interfering with Mix window colours | juba19 | Virtual Instruments | 0 | 08-09-2009 01:14 PM |
Strike graphics all yellow? | silentjdf | Virtual Instruments | 5 | 04-11-2008 05:49 PM |
