Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 08-19-2021, 09:03 AM
sricabla sricabla is offline
Default Spinning ball for 3 seconds
Ever since I upgraded to the latest PT for Mac, I have been experiencing during my mixing sessions a brief spinning ball for a few seconds and everything freezes but session keeps going and then back to normal. This is very annoying. It happens randomly and is becoming more prevalent. Does anyone else experience this bug?
Thanks in advance
Old 08-19-2021, 09:43 AM
gives's Avatar
gives gives is offline
Default Re: Spinning ball for 3 seconds
Thanks in advance
Hi There!
You need to include some system details for us to evaluate your issue.
Hardware, software OS Windows/Mac etc.
Model of Mac etc. See my info in my signature as an example.
G
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2021.10 Ultimate HD Native Thunderbolt Avid MTRX. DAD MOM, Dolby Atmos Mix Room, Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Catalina 10.15.7
Old 08-19-2021, 11:16 AM
gives's Avatar
Thanks in advance
Create a simple session without any plugins and start there recoding or mixing something and see if it happens. Then go from there.
Old 08-20-2021, 09:12 AM
Hello,
Here is my setup:
iMac 3.8GHZ quad core i5
32 mg Ram
Catalina
ApolloTwin X
Almost never more than 20 tracks
Old 08-20-2021, 09:21 AM
Many people have reported this issue. The only possible solution so far is a clean install of MacOS (not factory install) and clean install of Protools (not update). This issue seems to be most prevalent on Big Sur and on new M1-based Macs, but also affect other setups. Having said that, some people don't seem to have this issue at all, so it is unclear what the culprit is. As suggested, some suspect a plugin issue.
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.6 running Protools 2021.10
Old 08-20-2021, 09:45 AM
climber climber is offline
So...you know what causes the problem, AND you know the resolution. Right?
I don't understand...
Al Hospers
bass, vocal, composer, engineer
CleverSounds Recording
OS X Big Sur, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio , PT2021.10, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 08-20-2021, 12:14 PM
audiogamble audiogamble is offline
Have you, or has any other user done this successfully on their daily production machine? Can someone chime in and confirm that this is the fix?
Like, a current work machine doing heavy loads that gets used every day.
Old 08-20-2021, 03:57 PM
Originally Posted by Meads-who-was-banned View Post
How is that a resolution?
All you have to do is not connect to an NAS or run a backup while mixing or recording. Seems like a pretty reasonable solution to me. But of course YMMV…
Al Hospers
Old 08-20-2021, 05:08 PM
gives's Avatar
Good to know about..
Old 08-21-2021, 04:19 AM
I did this to my primary Protools system and don't get any beachballs. Now I don't claim to be a heavy hitter, more of just a hobbyist nowadays. I use MacOS 11.5.2 (Big Sur) but not on an M1-based Mac. I use mostly Avid plugins and some Waves and Isotope plugins. I also use Native Instruments virtual instruments. Let me also preface this to say that I did not have beachballs happening even before the fresh install of the OS an Protools. I did it as a good practice.
Some of the people experiencing these beachballs have this happen on small session using few tracks, so I can't say if this is a solution or not.
Obsidian Dragon
Lag/spinning beach ball every 10-20 seconds Tim R. Pro Tools 2020 31 10-16-2020 03:24 PM
Spinning ball when... SomeOtherGuy Pro Tools 12 1 03-27-2017 12:08 PM
Spinning ball problem in PT 11 OSX AndreasvanHaren Pro Tools 11 4 08-19-2015 05:22 AM
Spinning ball Mubeau Post - Surround - Video 5 08-15-2006 12:42 PM
Spinning ball at stop Faux Pas Pro Tools TDM Systems (Mac) 2 03-12-2004 05:38 AM
