Post fader inserts.
Since avid seems to be moving in motion slowly, I have a HUGE request for post insert faders.
As I bounce between PT and 32c, the latter gives me that function. How I use is, I place set my faders at unity and set my summing unit of choice to match 0db. So as I crank up the fader it drives into my summer or plug-in color of choice. Gives me that console drive. Sent from my iPhone using Tapatalk
WENT FROM HD TO M-POWERED
Re: Post fader inserts.
deleted
I’ll repeat it again. Since AVID is starting too WAKE UP, I have a request that I would love implemented. Sent from my iPhone using Tapatalk
deleted
What do you mean? Faders on audio tracks are post insert, but we tend to say that inserts are pre-fader. Or do you mean there should be a button that opens a gain control after an insert slot? May be pretty tricky to implement on a control surface, isn't gain control on a plugin enough for you?
Inserts on Master tracks are post fader signal flow. If you want to drive audio into an insert, this is one way to do it.
I’ll post a video on this later.
Just found out a few other daws have post fader inserts also Sent from my iPhone using Tapatalk
In the mixer in Mixbus 32c the fader is presented as a channel insert so you can place plugs in front of or behind it in the signal chain. You can also drag the fader insert to a new position. Some find this useful. DP also supports pre and post fader plugs on mixer channels.
PT 2023.12 DP 11.3 MOTU M4 HP Envy 8G i7 Quad Laptop Win11 PT 2023.12 DP 11.3 828es ADA8200 MTP-AV 2023 MB Air Sonoma VEP 7.x with various VIs on HP Z2 G4 Xeon Workstation Win11 |
YES! and I love that feature a lot. Sent from my iPhone using Tapatalk
Plays havoc with delay compensation and automation though...... |
Volume fader vs post send fader - same scale? | Vitopower | Pro Tools 2019 | 5 | 07-09-2020 06:11 PM |
Feature request -post fader inserts on tracks/aux | Sonsey | Post - Surround - Video | 15 | 07-13-2018 08:22 PM |
*BUG* Pre-fader sends revert to post-fader upon session restart | Nico Breeze | Pro Tools 11 | 7 | 07-11-2014 10:47 PM |
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? | Ricky Cobble | Pro Tools TDM Systems (Mac) | 5 | 05-05-2003 04:47 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
