Reduce Noise or Ask for a new Recording?
I'm currently facing a dilemma with a client where I must either work with a bad recording or ask for a new one. I usually run my own recording sessions however due to distance between the client and I, the supplied recordings have been full of noise and levels are not ideal. Considering how far along in the timeline since the start of the job, would it be wise to attempt to fix the problems post-recording through EQ/Noise gating, and mixing etc...or should I simply coach the client into improving his recording?
As for the mixing, the different takes he took all contain different amounts of noise (a NIGHTMARE to listen to and work with)...thus there will be different EQ settings and harsher mixing to make it work...any tips on what I should do or the best way to mix it out? |
Re: Reduce Noise or Ask for a new Recording?
I'd ask the client.
"Is it your preference that I mangle these tracks and charge you for that service, or do you prefer to provide usable tracks?"
Bob Without a song The day would never end |
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? | PeterGreen | Pro Tools 10 | 24 | 01-23-2013 06:38 AM |
How to reduce static noise from guitar? | Thing | Eleven Rack | 17 | 03-12-2012 04:16 AM |
how to reduce background noise | khardin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2005 01:27 PM |
How to reduce white noise/static? | Fladlien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-02-2005 04:28 PM |
CAN A VOCAL BOOTH REDUCE HIGHWAY NOISE????? | michaux | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-24-2003 06:47 PM |
