Old 03-25-2020, 08:05 AM
saspro saspro is offline
Default Loop Playback in MIDI = Loop Record?
When I'm record-engaged on a MIDI track, I often have Loop Playback engaged, as I've been rehearsing a piano part or something, and I want to now record it. Loop Record is NOT on. So I press record, record my piano part, and reach the end of my loop, and it loops back and starts recording a new region. This is Loop Record behavior, not Loop Playback behavior. Why does it do this?
This has dogged me for awhile.
Old 03-30-2020, 08:41 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Loop Playback in MIDI = Loop Record?
Hi if I understood well you want to check the midi/merge function. Maybe is disabled. See attachment
- Jesus Alvarado -
Keep the volume UP !
Old 04-01-2020, 07:06 PM
Nope. MIDI Merge was enabled (should've mentioned that). To clarify, I do NOT want it to Loop Record, I only want Loop Playback. When I record, it should only record once and not loop back and keep recording. Yet it does. Always has. Really annoying.
Loop playback with record enabled MIDI tracks fm_xtk Pro Tools TDM Systems (Mac) 2 07-04-2009 01:30 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
No playback loop with midi track in record SORTED! crizdee Pro Tools TDM Systems (Mac) 2 01-15-2007 08:37 AM
Playback during Loop Record? Mr. Bojangles Tips & Tricks 1 11-27-2000 04:01 PM
