#71
Re: APFS or Extended Journaled for session drive?
Thank you Darryl for that straightforward response and I totally agree with you especially when it comes to Avid's "approved systems". I don't think I have ever run on an approved system myself ever since I started working with Pro Tools. I never implied that Avid's document was more informed than people posting in this thread, quite the opposite actually but as you mention yourself, some of the info posted by Avid online is very important and some is ... not. It's not always easy to figure out which is which and seeing the document on formatting drives was "updated" in september 2020, I now understand why you've given up asking them to fix it.
Thanks again for clearing that up. One last thing, are you suggesting with modern macs and PCIe/NVMe SSDs that system, audio sessions and sample/VI libs could all reside on the same APFS drive ? |
#72
If you need an external drive on a modern Mac then a modern NVMe/PCIe SSD connected over Thunderbolt 3 will give you performance about the same as the internal SSDs. That market is still not quite sorted out with drives like the Samsung X5 overpriced, packaging your own M.2 SSD in a Thunderbolt 3 enclosure a better cost but maybe bit fiddley option, and high-end options for multiple M.2 drives in PCIe expansion chassis are there but complicated by PCIe card options and running into Thunderbolt 3 performance limits, and you kinda need to know what you are doing with card and/or RAID choices. I hope with increasing use of Thunderbolt 3 as an optional part of USB 4 we will see better external PCIe/SSD storage options. And of course many PC, current Mac Pro and classic Cheesegrater users have great options for M.2 direct (PC) and M.2 on adapter cards in internal PCIe slots... in those cases I sure would be more tempted to avoid the Apple tax on large boot SSDs and spend it on third party M.2 drives. HDD remain good options for backups, especially archival type backups. Last edited by Darryl Ramm; 02-05-2021 at 09:30 PM. |
#73
Great, this is everything I was hoping to read when it comes to setting up my Pro Tools rig with APFS and PCIe/NVMe SSDs. This is gonna make things much simpler. Now I need to figure out the best option for a portable TB3 NVMe SSD with my audio sessions to go back and forth between studio with cMP 5,1 (still no flashed Titan Ridge PCIe card installed) and my home 2020 iMac.
#74
Yes, and also good enough for most sessions if sample drives are SSD
#75
#76
Lots of past discussion on NVMe drives in classic Cheesegraters on DUC if you have not seen that yet. |
#77
Good enough is not always good enough.
#78
I've always pushed back on trying to get TB3 inside a cMP for those exact reasons. Up until now, I was satisfied going from studio to home rig with my Oyen Digital MiniPro eSata SSD enclosure connected to PCIe card (internal mSATA SSD for startup + external eSATA connector) on cMP and Sonnet eSATA to TB1 converter on iMac. That worked really well for a long time. Now that I have very fast internal PCIe/NVMe SSD and TB3 at home and still need a portable sessions drive, I'm not sure how to connect a TB3 SSD to cMP without taking the Titan Ridge route.
#79
#80
Journaled or Extended... | delaplanemusic | Pro Tools TDM Systems (Mac) | 5 | 04-14-2008 01:35 AM |
Journaled Drive | SteveGarman | Pro Tools TDM Systems (Mac) | 4 | 12-05-2006 01:47 AM |
EXTENDED Vs JOURNALED HD FORMATS | Dual Mackie | Storage Subsystems | 3 | 02-25-2005 04:41 PM |
Mac OsX Extended Journaled Problem | Luis Miguel | Storage Subsystems | 4 | 11-03-2004 07:21 AM |
Format Extended or Extended Journaled for PT6.2.3? | AAR | Pro Tools TDM Systems (Mac) | 3 | 02-06-2004 07:46 AM |
