2024.6- CPU overloads when stopping transport
My super-stable system is no more following installation of 2024.6.
In my composing template and every session based on it - there are getting on for 200 tracks - mostly Instrument Tracks fed from VE Pro. Whenever I hit stop - there’s a massive 100% CPU overload on every core which lasts a good few seconds and PT is unresponsive. During the overload, the MIDI activity monitor on every channel within VE Pro goes crazy although I can’t hear anything fortunately! I’ve done much troubleshooting including deleting PT prefs twice with PT Prefs 2. I’ve deleted VE Pro prefs and also re-installed it. I’ve also uninstalled every new plugin I’ve added in the last few weeks. Everything is at the current version. So far - I’ve concluded it’s related to FabFilter Pro Q-3. I have it on every track in my template. If I make every Q-3 instance inactive - the problem goes away. If I replace Pro Q-3 with the Avid EQ III 7 band - the problem goes away. Previous to 2024.6, there wasn’t an issue. I’ve also turned MIDI off in every instance of Pro Q-3. If I make inactive the five instances of VE Pro in the session, again the CPU overs stop. I’ve been working on two other sessions with no VE Pro but lots of Pro Q-3 instances with no problems. Any ideas?
Dave Marsden UK |
Re: 2024.6- CPU overloads when stopping transport
There was a FabFilter update about a month ago. Try that.
Thanks.
Yes that's the version I have installed and I actually re-installed it this morning!
Dave Marsden UK |
I’ve rolled back to 2024.3.1 and the CPU overloads have stopped. Normal service is resumed.
At least on my system - it seems there’s something funky going on between PT 2024.6 and VE Pro.
Dave Marsden UK |
Hi Marsdy,
we have exactly the same problem on our MacPro 5,1 HDN systems. M1 macs with core audio running fine. Posted it here: https://duc.avid.com/showpost.php?p=...8&postcount=15 Opened case no. 04822896 We use Pro-Q3 a lot in our templates. When I have some time between projects, I'll try 2024.6 again with deactivated Pro-Q3. Best Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D ------------ mars13.de |
If anyone here is using the plugin Scaler, I found that this was giving this exact behavior. Make it inactive or remove it from your session.
Yeah, I just tried Pro-Q3 and Pro-Q2 on 200 tracks and I get the same results. 100% CPU Spike when you stop the song. This didn't happen with Pro Tools 2024.3.1. I'm also finding other plugins with the same issue like the SSL 360 Link Plugin.
Pro Tools Studio 2024.6 & Ultimate | Logic Pro 11 | Studio One Pro 6.6.2 | Dolby Atmos Render 5.3 & Album Assembler 1.4 | RME BabyFace Pro FS | UA Native Plugins & Sphere LX | SSL UC1 | 2023 Mac Studio M2 Max 12 Core CPU 38 Core GPU | MacOs Ventura 13.5.0 | Genelec 8020D & Yamaha MSP10 | Korg Kronos LS | Sonarworks Sound ID | Beyerdynamic DT 1990 Pro | DT 880 PRO | DT 770 Pro | etc. Last edited by ZoeMusic; 07-20-2024 at 09:29 PM. Reason: added info |
Ah the old days of de-normalization problems triggering CPU overloads with stopped transports. No clue what the issue is here, but if nothing else the pain may be nostalgic...
Thanks for confirming it’s not just me and isolated to my system!
Dave Marsden UK |
Hi there
quite similar here (See attachment): "Pro Tools timed out trying to stop" on low (<256 Samples) buffer sizes. Pro Q 3 is in the session and quite a bunch of VI's and so on. I regularly need to "Force Quit" Pro Tools after such an event as it freezes after playback stop. 2024.3.1 worked flawlessly with low buffer settings. Last edited by KlangKraft; 08-03-2024 at 09:53 AM. |
Playhead jumps forward after stopping transport | CamM | Pro Tools | 4 | 08-18-2023 10:00 AM |
Edit window keeps jumping to bar 45 when starting/stopping transport | DJ Hellfire | Pro Tools 12 | 0 | 01-16-2016 05:07 PM |
Kore player stopping transport controls | paulwilks | Virtual Instruments | 1 | 10-10-2011 06:26 AM |
Transport Window inconsistent stopping playback | beverlysfield | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-18-2005 11:18 AM |
Stopping playback returns transport to zero? | TimInVan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-13-2002 04:49 PM |
