Mis-matching bar length
I've got a wierd meter thing going on, on a session. The tempo and meter don't change but at bar 13 of the session the bar is shorter than the rest. Is thsi a know bug?? How can I solve this? I've not up graded to version 8 yet. Thanks Ian.
MacBook Pro, Intel Core 2 Duo, 2.2 GHz, L2 Cache: 4 MB, Memory: 4 GB, Bus Speed: 800 MHz Mbox2, Pro tools 8.0.4 |
Re: Mis-matching bar length
Your first statement is a little ambiguous...
So if you just want the same tempo and meter through the whole song... Are there any meter change events in the meter ruler? Anything in the tempo ruler? Is this just a graphic glitch, or does the song play back weird, too? You could probably tell pretty easily by what the click track is doing.. Can you tell by zooming in on the grid, and maybe setting the grid to a smaller value, exactly what is strange in measure 13? Is it the tempo speeded up or is the meter changed? Have you used Beat detective at all?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Well yes I want the meter and tempo constant. There are no meter changes it's just that at bar 12 - 13 has a different length to the rest. There are no meter changes or tempo changes there neither but the track is affected sending everything out.
No beat detective was used at all.
I think I've sorted it. I went on the meter window and at bar 12 it had inserted a meter change but the funny thing was is was still 4/4 and 72 bpm but for the next bar it was a weird length.
Drawn MIDI note length only staccato notes, regardless of note length | kingofallwookies | Pro Tools 11 | 2 | 02-07-2014 08:10 AM |
Copied region length auto-adjust to paste location length? | greglawrence | Tips & Tricks | 4 | 10-23-2011 01:46 PM |
EQ Matching | Moviesound | Post - Surround - Video | 35 | 05-30-2010 10:44 PM |
The Matching Criteria List and Matching Playlists | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-13-2009 02:35 PM |
Matching EQ | stealth | Tips & Tricks | 6 | 11-10-2001 01:14 AM |
