  #21
Old 11-23-2021, 04:26 PM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is online now
Default Re: Ultra Wide Monitors Woes Woes With Mac mini M1?
USB 4/Thunderbolt 3 cable arrived today. So far so good!
It seems HDMI sucks?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
  #22
Old 11-23-2021, 04:38 PM
JFreak's Avatar
JFreak JFreak is offline
Working well here.
Why do I need to keep repeating this everywhere? Is my software install somehow superior and cabling so overpriced that I do not see the issue?
Just as confused.
Janne
  #23
Old 11-24-2021, 05:16 AM
Originally Posted by JFreak View Post
Working well here.
Just as confused.
Who knows. One thing is for sure, after trying four different HDMI cables connected to two different UW monitors without a cure, it is easy to see why I came to the conclusion
On the plus side, I have used HDMI without any issue for years. Maybe HDMI is just on its path to legacy and these cracks are the warning signs? It will almost certainly go the way of SCART sooner or later, that is certain.
Stephen
  #24
Old 11-29-2021, 07:02 AM
eightamrock eightamrock is offline
Stephen
Glad you got this resolved finally! Sorry for leading you down the path of another HDMI cable, but I can tell you I had the EXACT same issue. After noodling with cables for a good few months, I finally resolved it this way.
Regardless you are now flicker free!
  #25
Old 11-29-2021, 01:53 PM
capt kirk capt kirk is offline
Personally, HDMI is NOT a professional connector, and is the worst designed piece of **** since the rca jack.....
www.kfaudio.ca
  #26
Old 11-29-2021, 01:57 PM
Just thinking about them makes them fail....
www.kfaudio.ca
  #27
Old 11-29-2021, 02:04 PM
JFreak's Avatar
HDMI have so many different spec already, and cables differ accordingly. Biggest problem however is that the cable is not locking type. If it is even slightly loose, it fails or stutters.
Strangely enough, to repeat myself, When I switched from 2013 MP to fully loaded M1 mac mini and used same cables I had zero problems with my monitors. But I don't think how ultrawide you consider these (3440x1440 via HDMI and 2560x1440 via TB)
Janne
Mini Grand Woes eheilner Virtual Instruments 4 08-13-2021 10:06 AM
Ultra wide monitors ZEUSS Pro Tools 11 2 12-27-2014 11:35 AM
Regular Ultra wide -Ultra 3-enclosures the same? elementsound Storage Subsystems 0 07-03-2004 01:43 AM
001 w/B&W G3 Ultra Wide espmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2000 06:40 PM
ULTRA WIDE 3 LVD jjblair General Discussion 3 02-10-2000 09:37 AM
