#251
Re: -9171 and -9172 errors with Pro Tools HD 10.3 on HDX
I've noticed a HUGE improvement in the stability of my HDX system since cleaning up some plugin redundancies that had between .dpm and .aax plugins a few weeks ago. I went through and removed any .dpm plugin that had an .axx substitute.
Doing this might make backwards compatibility difficult for some if you need to open older sessions that used .dpm plugins. (Maybe I'm wrong on that and PT10 will automatocally know to use the aax version instead) Anyhow, this has dramatically decreased my -9171 and -9172 errors. In fact I haven't had one in a few weeks. Not one. (knock on wood). I had pretty much parked the buffer at 512 for the last month and this was a big help as well. Today while mixing a 44.1k session, I decided to knock the buffer down to 128. Not a single error all day. Let's see what tomorrow brings...maybe I'll try 64. Hopefully this helps some of you out.
SHIRK www.shirkmusic.com www.hearya.com MacPro 12core 3.46Ghz (5,1) OSX v10.14 48GB RAM 1x HDX 2x HD i/o 16x16, 1x Digi192 8in/16out Pro Tools Ultimate 2021 on HDX |
#252
Pro Tools Ultimate 2021.10 - macOS Big Sur 11.6 10 Core iMac Pro 64GB RAM - Radeon Pro Vega 56 8176 MB UA Apollo x8 |
#253
#254
When I first installed PT HDX in early February Running HDX 10.0.1 (1st version) with the original HDX card firmware and OSX 10.7.2 (Same OSX version i'm still at today) I was getting -9093 & -9094 errors like crazy.
I gathered and tested and came to the conclusion that 99% of those errors were related to or directly caused by 3RD PARTY PLUGINS. VIs included with Native Instruments being the worst offender. Now im at the configuration in my sig below. Almost instantly after upgrading the PT software and card firmware(Still on OSX 10.7.2) I began receiving -9171 and -9172 errors like crazy. I believe the bug lies somewhere between the software/firmware update and further incompatibility with 3rd party plugins. PT10 is a pretty important version for us because its the TDM/RTAS transitional version, a lot of accel users will stay at PT10 long after PT11 because of its added functionality and recall ability of TDM/RTAS. Its REALLY important that AVID makes a stable version of PT10 able to play nice with most 3rd party plugs. After they do they can abandon this old code and leave it for dead. |
#255
I'll try it this weekend too. Thanks. Last edited by Andy R; 12-14-2012 at 04:42 PM. Reason: Quote |
#256
Nope, no joy here.
I can tell you one thing tho... Kontakt 5.0.3 seems to be a train wreck in, or outside of PT. ^_^ |
#257
Boe |
#258
a buffer-size of 512 or higher is just a very expensive version of pro tools native...
i bought HD Accel to not worry about buffer-sizes, pops and crackles... and i bought HDX for the same reason. i can´t use my outboard correctly, as the vu-meters are way behind what´s beeing played with a buffer of 512 or higher.
Selling: |
#259
@SHIRK / Boe / psmworld - Are you guys using any Avid, or 3rd party VI?
Thanks in advance. |
#260
no
Selling: |
Pro Tools 10.3 9171 and 9172 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 20 | 07-14-2013 03:11 PM |
-9171 and -9172 errors constant...Sandra attached | wrachilla | Windows | 12 | 05-09-2013 09:19 AM |
UAD triggering 9171, 9172 errors? | xq3js | macOS | 7 | 03-22-2013 11:47 PM |
Dae errors -9171 after installing 10.3.3 | TCM | Pro Tools HDX & HD Native Systems (Win) | 3 | 02-06-2013 10:18 AM |
10.3.3 Major Fail....9171, 9172 and 9129 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-21-2012 07:21 PM |
