Drum plug in advice
So I used to program my drums with a synthesizer editor but I want to try it through a Pro Tools plug in now. What are the best drum programs for complete drum track editing? I don't want to use preset looped beats. I want a program that allows me to compose original beats, fill, rolls, and so on down to the exact BPM. Thanks in advance
Re: Drum plug in advice
I'd use the Search function. This question comes up very often here. I'll start - Toontrack Superior 2. Let the mayhem begin.
I checked the lite version of toontrack EZ Drummer and it seemed to be more loop focused. So toon tracks editor is pretty in depth?
I'm a little confused on why you don't just use the midi sequencing and editing of Protools vs. wanting it to specifically be in the drum program itself.
Honestly, I've recorded in the more traditional way using software minimally and primarily just for multitrack. I'd lay my guitars, vocals, keys, bass all from external instruments. My drums were programmed on a korg sequencer by programming, not playing. I've never worked with midi within the DAW. Would I play the beats from the Midi controller then adjust them on a map? Maybe you could point me to a simplistic tutorial for the basic. Thanks.
Most Drum Programs have the same Midi Notes for all of the drum parts Kick, snare, Hi Hat, Cymbals, Toms, So I usualy bring up Xpand2 using the Drums Program find a Kit for the type of song/Music IM writing at the time and play the Drum into a Midi Track and record that from my Axiom 61 or the Pads on the Axiom, that way I have the Midi Notes for all the drums and I can change the drum sound patches out latter, double the drum parts with other Drum VI and I can use the Midi Editor to enhance the drums and change sections in the song.
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Using the midi controller within Protools allows a lot more flexibility and ease of use, especially to change it after the fact, not only switch out sounds, but velocity, timing, etc.
There are a lot of functions so it can seem intimidating at first, but I think you'll enjoy it once you get used to it. I don't know of specific video tutorials on drum programming in protools, but you might check out Groove3.com, to see what they have. I can highly recommend a book that's not very expensive, called "Producing in the Home Studio with Pro tools" by David Franz - 3rd edition: http://www.amazon.com/Producing-Stud...0779418&sr=8-1 This really helped me with all aspects of protools and there's extensive coverage of working with midi. This book came out before Protools 8, but 95% of it still applies. You can find out the updated midi features or protools 8 through other sources. |
I'm a Strike fan. But have no problem using Superior Drummer 2. Both are very good. Addictive Drums is very good, as well as Battery 3. I'm not a BFD fan at all, but again, the sounds are good. and if you are looking for Cinematic/orchestra drums, then True Strike 2 is amazing. And Morphestra also has some great cinematic hits in it. I have all these programs, but for "normal" drums as in for a rock band, pop, metal, ect, i just like Strike or Superior Drummer best. Listen to samples, try any demos, and choose the one thats best for you. Battery 3 Morphestra True Strike 2 Strike (Youtube) Digidesign Strike Superior Drummer 2 BFD 2 Addictive Drums
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Yes, for instance these:
http://www.youtube.com/watch?v=xUX6l45x4iE were played using an electronic drumkit into Pro Tools as MIDI while triggering BFD2 You can use any MIDI device to record the MIDI... These were recorded using Superior Drummer 2.0: http://www.youtube.com/watch?v=KMw2b2mC4DQ and the demos on this page were drawn in using a mouse on a MIDI Track in Pro Tools: https://www.platinumsamples.com/JoeBarresi.html Rail
Drum programmers - advice please | amiller | The Drum Room | 33 | 10-17-2009 06:37 PM |
New to Drum plug in's - need some advice | Room335 | Virtual Instruments | 12 | 11-17-2007 03:04 PM |
Advice on Drum Mics | skylab001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-13-2004 12:48 AM |
Advice on Best Drum Loops CD | Chence | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-06-2003 01:22 AM |
Drum Loop Advice | 2 bit | Tips & Tricks | 4 | 10-10-2000 12:19 AM |
