Old 01-10-2023, 06:20 PM
szs szs is offline
Default ADM file normalization
Hello everyone.
I am working in an atmos mix that is -18lkfs and I need to take it to the Netflix standard -27lkfs.
What I am doing right now is open the ADM file in pro tools and inserting the Hornet Samp plugin on every channel to reduce gain, but my true peak reading is a little low.
Can you share with me what is your preferred method to get the ADM file into norm?
Old 01-10-2023, 06:53 PM
its2loud its2loud is offline
Default Re: ADM file normalization
Originally Posted by szs View Post
Hello everyone.
Mix it correctly to spec to begin with. -18 to -27 difference is a lot also not to mention that -27 lkfs dialnorm spec is probably going to read differently than the original -18 mix. Also. Just because the TP is -2 doesn’t mean you have to hit that number.
Old 01-11-2023, 06:44 AM
originalscottyg originalscottyg is online now
A -18LKFS mx turned down to -27 is still going to be a -18 mix in terms of dynamics, e.g. compressed any not very dynamic. As mentioned it would be best to get back to the original session and remix properly at -27.
And as also mentioned, make sure to measure properly for Netflix using the -27 dial norm setting, this will yield different results than just measuring the whole mix at a standard -27LKFS.
Scott Gatteño
Old 01-11-2023, 08:44 AM
szs szs is offline
You are both right. Thanks a lot for your feedback.
HTML code is On
Batch Process Normalization? pAndAmOnkEY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-21-2017 08:04 PM
Clip Gain Normalization? jchan Pro Tools 12 15 10-12-2016 02:56 PM
Normalization Short Cut pAndAmOnkEY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-08-2011 11:11 AM
Normalization GothicV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-04-2004 10:52 PM
Normalization clicks whayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-12-2004 10:40 PM
