Old 01-27-2023, 04:39 AM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: S6 showing fader value 0.0 falsely
Is this regardless of the session? What version of S6 are you on? I'm still confused as to how intermittent this is. Can you randomly check any other channels in the session and one possibly behaves that way but it's not specific to a physical hardware fader?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-27-2023, 08:06 AM
EddieJones's Avatar
Is it possible for you to update to 2022.12 and see if this issue still happens?
Old 01-30-2023, 03:57 AM
stefanboman stefanboman is offline
Jeff,
Yes it seems to be appearing randomly of most sessions.
Haven't noticed it when starting on a fresh mix but often when picking up a session a few days later.
Also seems completely random on which physical fader it appears on.
And to make things even more difficult to grasp is that it doesn't have to be like that on all faders(once it appears).
I've seen a few times that for example faders 1-3 shows the value correctly but 4-7 shows 0.0(falsely).
But like I mentioned before it's not bound to any physical location and could appear anywhere on the console.
Did discover one thing today, I was shown 0.0(falsely) on a fader today, put that fader in Trim mode. Then once I exited Trim it showed the correct value!
If that can give you any clues...
Eddie,
Unfortionatly I still get it on 2022.12
Stefan Boman
Atlantis Studios-Stockholm
www.parkstudios.se
stefan[at]atlantisstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 02-07-2023, 04:49 AM
Any suggestions Jeff/Eddie?
Or do I have to start a case about his?
Would be great to get this solved or at least have something to try out.
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 02-07-2023, 05:05 AM
Sadly, the intermittent nature of this issue makes it exceedingly difficult. Unless Eddie has additional suggestions, I would start a case so they can dig into it, examine logs and look at your network configuration:
https://avid.secure.force.com/pkb/ar...-Case-Creation
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Dock fader showing wrong channel until touched OAG Avid S1, S3, Dock and Control App 1 07-22-2021 09:24 AM
S1 and showing fader groups copesetic Avid S1, S3, Dock and Control App 4 12-09-2020 09:59 AM
System Usage showing <10%, Activity Monitor showing >110%. What is going on?? colliderman Pro Tools 2020 13 06-17-2020 01:49 PM
SC48 Channel Fader showing as "OFF" BD123123 VENUE Live Sound Systems 3 11-24-2013 02:35 PM
FADER MUD - IMPOSSIBLE TO MAKE FADER WRITES IN REAL TIME Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2007 10:34 AM
