Old 11-13-2004, 03:42 PM
stoneact stoneact is offline
Default Audiosuite Menu won\'t open
I'm running ProTools Free on Mac OS 9.2. First time user. I've just made some audio voice recordings into a track and I am now ready to edit the recordings. I want to normalize the recordings and do a DC Offset Removal. This is located under the AudioSuite menu. For some reason, the AudioSuite menu tab is grayed out and won't let down. Please help.
stoneact
Old 11-14-2004, 03:24 PM
M.Brane M.Brane is offline
Default Re: Audiosuite Menu won\'t open
Are the plug-ins present in the System folder->DAE folder->Plug-ins folder?
Why do you want to normalize?
Old 11-16-2004, 03:39 PM
Thanks for replying. I was told to use the normalize function to make all my recordings the same volume. For example, I've recorded several voice recordings on the same track and I was told to make them all sound the same, normalize.
I didn't find anything related under the system folder-dae folder-plug-ins
Old 11-16-2004, 09:16 PM
All normalizing does is raise the peaks to 0db, and the noise floor along with 'em. Better to limit/compress the files so the perceived volume is the same, and leave yourself a few db of headroom.
The gain plug-in does the same thing as normalizing, but at least with it you have control over how much the level gets raised. I often use it to reduce levels on hot files to preserve mix headroom without having to lower the faders a lot.
If the plug-ins are not in the folder I wonder where they are? If you can't find 'em you may have to re-install. No wonder the menus are greyed out.
Old 11-17-2004, 12:26 PM
You rock M.Brane!!! I reinstalled, normalized and everything's groovy!!!
Thanks a bunch!
stoneact
HTML code is On
audiosuite plug at top of menu omnitarian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-31-2011 11:18 AM
Duplicates in Audiosuite menu jnorman16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-07-2004 02:48 PM
Audiosuite menu and new Plug-ins Driven1 Digidesign Hardware & Software 14 09-21-2002 11:04 AM
Help...Audiosuite menu Non-existant??? Dj Winter Digidesign Hardware & Software 2 03-17-2002 07:18 PM
AUDIOSUITE MENU [email protected] Pro Tools TDM Systems (Mac) 1 05-04-2001 01:35 AM
