Excessive UAD Latency in Pro Tools on 2019 iMac
Does anyone have heavy latency problems with UAD-2 plugins in Pro Tools? I'm running a UA Apollo Twin X Quad and Octo Satellites DSP with a 2019 iMac 3.6 GHz 8-Core Intel Core i9, 128 Gb RAM, 5TB SSD machine. It is an SSD Fusion drive with PCI Express - both drives are SSD.
Even putting one plugin on a track in an empty session brings a crazy amount of samples latency in PT Delay Compensation. The SSL E 4K Channel Strip for example is at 2103 almost 40 times what the UAD Latency Values Table. It's not every UA plugin just certain ones. I've tried Pro Tools 2024.3.1, 2024.6 on Ventura 13.6.7 and Sonoma 14.5. Does anyone either have a similar setup or know what could be happening? Is this a Fusion drive problem, Thunderbolt Buss issue with this iMac, or something else?? Thanks |
Re: Excessive UAD Latency in Pro Tools on 2019 iMac
This will all be working as expected, so likely a user understanding issue, and there are multiple things to understand here. UAD DSP plugins in DAWs are terrible for latency, they are significantly more latency and often more hassle than native plugins.
The latency you are looking up in that table is the additional latency within the plugin. You also have to account for the H/W buffer latency in getting out of Pro Tools over the damp string to the UAD DSP and back again. This stuff is explained in the UAD systems manual. You should probably not be trying to use UAD plugins in Pro Tools for tracking, it's more intended for mixing, where this won't matter as long as it is withing limits ADC can handle. With the high latency of getting to the DSP you have very limited ability to run the H/W buffer at smaller sizes and keep all this stable. If the UAD plugin are not used on a live input/motioning signal path then they will use the large playback buffer of 1024 or 2048 samples not what you set in the H/W buffer size. This is the whole purpose for the Apollo Consoles and ability to run UAD DSP plugins in the console without this H/W buffer introduced latency. Just running native plugins can get many users all they need for mixing and monitoring/tracking. Unfortunately the SSL 4000 plugins are not available in native from UAD. If you want to monitor though this plugin while tracking you should be instantiating it in the UAD Console in your UAD Apollo Twin X Quad, not in Pro Tools. |
As Darryl said. absolutely normal. Everyone who uses UAD plugins on their DSP platforms (Apollo, Satellite, etc) deals with it. The UAD native/Spark versions are better for that reason.
Pro Tools Ult 2024.6, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 14.6.1 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I first saw this problem because the OP is using Superior Drummer 3 (which I use) and he thought it was a problem with that vi so he's staying ITB. Given that I have to wonder about his routing - plugins on a track with no audio routed to said track from within the session. Wouldn't that also be a factor which I think Darryl kind of mentioned. Also in his post over on the Toontrack SD forum he said he was running into the issue when mixing. He's not giving the same info here and on the SD forum.
Here's a link to the thread over on the SD3 forum but the issue is you have to have an account there to even just read the thread: https://www.toontrack.com/forums/top.../#post-3278035 Attached is a screenshot of his first message there. His name is Pete Risi Last edited by musicman691; 08-10-2024 at 04:06 AM. |
OP- You are getting about 1000 SAMPLES MORE latency than I am getting on my MBP 2020 Intel, OSX Ventura, PT 2024.6 and UAD Arrow. Session is running off an external SSD. PT buffer size makes no difference in latency concerning UAD plug ins, which is expected. Maybe it's your routing?
edit- routing looks normal |
you are so full of yourself and won't admit when you have no idea what you are talking about. I have been using UAD for almost 20 years. F U |
2019 iMac vs 2019 Mac Pro | Peterjk | Pro Tools HDX & HD Native Systems (Mac) | 7 | 01-14-2020 12:23 AM |
Imac early 2019 with Catalina and pro tools is not working | luism | macOS | 8 | 12-21-2019 05:23 AM |
2019.6 Ultimate and iMac Pro are NOT happy together... | Eric Seaberg | Pro Tools 2019 | 17 | 08-20-2019 06:16 PM |
Mac Mini i7 2018 vs. iMac i9 2019 | George2000 | Pro Tools 2019 | 4 | 08-07-2019 10:16 AM |
Best Imac for Protools 2019 | larsongs | Pro Tools 2018 | 133 | 01-06-2019 12:23 PM |
