Old 07-04-2024, 03:27 PM
Thenewexhibit Thenewexhibit is offline
Default "Save" is disallowed (version 2024.6.0)?
"Because this last session was opened with a Pro Tools version (2023) that has a different format of ARA data which is not supported in Pro Tools 2024.6.0.
Click "Save As" to create a Pro Tools 2024.6.0 compatible copy of the session. The original session will be unaffected."
Has anyone else seen this? I assume it's pretty standard, but I was hoping that I could just save this and overwrite it and keep the same name as opposed to doing a save as? I guess not a big deal, but I assume you guys have run into this? You gotta do this for every session that was before 2024.6.0?
Mac Pro (Late 2013) OS 12.7.3 (Monterey)
3 GHz 8-Core Intel Xeon E5
32 GB Ram
1 TB OWC internal SSD (running off of bootable Monterey Samsung T7 test drive)
AMD FirePro D300 2 GB
Pro Tools Studio 2023.12.1
Audient EVO 16 w/ two Audient EVO SP8's via ADAT
Old 07-05-2024, 04:03 AM
climber climber is offline
Default Re: "Save" is disallowed (version 2024.6.0)?
I've never seen this personally... How do you version your sessions? I do SessionName-yyyymmdd.ptx. Makes it easy to save-as. That said, save the session as a new name, rename the old file, then rename the new one to what it was. :
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2024.6, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 07-05-2024, 10:43 AM
Thanks for the reply! So, this is strange! I don’t know why this would be popping up. I will add that I have both 2023 and 2024 installed on my computer, and I renamed the older one to Pro Tools 2023 so that I could test out 2024.6.0. I don’t know that that would have anything to do with it though, as I’ve never had that happen before.
I’d like to hear if anyone else is experiencing this.
32 GB Ram
Old 07-05-2024, 09:57 PM
its2loud its2loud is offline
2024.6 has a different way of saving ARA data than previous sessions did. Therefore, when opening an older session that contains ARA data with 2024.6 and then changing any ARA data, it will ask you to do a Save As. It’s not a big deal and keeps the old session intact in case you need to open that one up with anything below 2024.6.
Page 14
https://resources.avid.com/SupportFi...4.6.pdf#page18
"Could not save "" because while translating Paths." - can't save ptx 2022.12.0 zachxweeks Pro Tools 1 03-12-2023 11:39 AM
2022.9 crash after using "SAVE A COPY" and choosing "Audio Files" tomhartman Pro Tools 2 12-09-2022 08:00 PM
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 03:43 PM
Why no "Save As"? How do we save changes to a new version without overwriting? BLG Pro Tools | Intro Discussion 12 03-25-2021 03:10 PM
do i have to buy "european" version of digi002, or use "american" with power adaptor? stoka General Discussion 3 10-04-2002 05:28 AM
