Old 06-16-2023, 07:59 AM
gdgross's Avatar
gdgross gdgross is offline
Default adding or cutting time and playlists
Is there a way to make all playlists in a session follow any add/cut time modifications?
Sometimes I'm editing a song form, and want to change it slightly, then later I might also realize there's a wonky note or syllable or something after I've done the form changing. Going through previous takes when they don't align any longer with the song is kind of annoying...
Any tricks?
Thanks, happy Friday!
Geoff
www.merlotembargo.com
Old 06-16-2023, 10:49 AM
nednednerb's Avatar
nednednerb nednednerb is offline
Default Re: adding or cutting time and playlists
The steps that I think are necessary, just before you add or cut time, is to select all or select only the tracks you want to NOT preserve existing timing (what you said sounds like you want playlists to follow the cut/add or in other words, NOT preserve).
With ALL group enabled, or the intended tracks selected (then Alt+Shift-click), or simply Alt-click whenever without grouping or selecting, on the Track View Selector, and choose "playlists" so that ALL the tracks you want to "follow" are in playlists mode.
THEN, when you add or cut time, the underlying lists should follow.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 08-10-2024, 08:42 AM
chompers2022 chompers2022 is offline
Yes, but that does NOT address the issue that the playlist channels are not included in the selection unless you painstakingly drag the selection across ALL the playlists in the session. ARGGGHHHH. this has been an issue from day one of the playlists era. WE NEED to be able to include playlists in the "all" selection option. PLEASEEEEEEEEE
Old 08-11-2024, 06:36 AM
R4000 R4000 is offline
Yes it's a pain. I do a lot of conforming across playlists and find going into playlist view and then dragging across the top ruler to select all playlists for the section is the best way to select them all (hiding any tracks you don't want to include).
We do need a button option to include playlists in a conform... long overdue.
Cutting and Inserting Time with Melodyne seanmccoy Pro Tools 2020 5 01-05-2021 01:52 PM
Moving all Playlists at the same time? Drew Mazurek Pro Tools TDM Systems (Mac) 5 08-25-2014 08:54 AM
Cut time and Playlists neev1073 Pro Tools 10 2 11-13-2012 05:56 AM
Cutting Time question Great Divide Studios Pro Tools TDM Systems (Mac) 1 04-23-2008 03:12 PM
cutting time out of song Ziko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-14-2006 01:47 AM
