delay when punch recording
I have a new glitch that showed up last week on both my mobile studio (titanium and m-box) and g-5 machine using 002.
When I set a preroll and hit record the machines go into a 4 or 5 sec pause before starting the preroll playback. It also happens without the preroll when just hitting refcord. I have been recording this way for years and this just started on both machines., I am sure it is something I have done. Any ideas what it is. On the laptop last week I was using a virtually new glyph drive so fragmentation is not the issue and on the session today I was using a drive which had just had disk warriour run on it. This is very annoying so any help would be appreciated. Jeff |
Re: delay when punch recording
Sounds like you have your 2 bar countoff set to on.
Open your and expand your transport window so it shows MIDI information, then click on the 2 BAR button. If it is Blue, it will wait 2 bars before starting to record, if it is Grey, it will start immediately. I found in 6.7, it goes on and off randomly.
www.hypeschwartz.com Digi001 (RME adi-8 pro) G4 MMD Dual 1g + 1.25g RAM PTLE 6.4 (DVToolkit) Mac. OS 10.3.3 3 Lacie 80g FW Audio Drives |
No it doesn't... but you can toggle it using the numeric 8 key.
Rail
Errr, yes it does! One session will open with it selected and another will not, without changing anything. If I turn off the 2 bar countoff, it will remember that, but when I start a NEW session, it might open with it on or off, no telling why? My sollution has been to leave the expanded MIDI transport open so I can tell if it's on or off.
Rail, you're not being very helpful. How about suggesting what you think it is huh? instead of just catagoricaly denying that in fact that's the case!! Man???
If you see unusual behaviour like you describe.. follow the sticky troubleshooting tips - esp. about trashing your prefs.
Rail
I understand that and do so regularly. The problem showed up on a brand new install of PT TDM on and HD3 Accel system G5 Dual 2ghz w/6.7.It presented itself in different forms thruout the night with exactly the same setup and without even quitting PT.
It so happens that we were doing a live recording in a theatre, so this needed to be sorted out, 'cause we didn't have much time to troubleshoot between sets and sessions and it was very bothersome to find out it had changed in the split second that the band started to jam as we hit record, only to find out that the 2 bar countoff had been enabled and that we might have missed the first couple of beats. I'd never experienced this before either, so it came to mind when I heard this poster having the same problem. That's all I'm suggesting. My sollution for now is to leave the transport extended so I don't have any surprizes. Hopefully when I get 6.9 loaded up, it'll be fine again.
Thanks to you all. It was the midi and I am sure the toggle on the keypad 8 is what I did, but since I did not have the midi controls visible, I didn't know I did it.
Thanks for the quick response. We had a very annoying day yesterday because of it and today should be much better. Thanks Jeff |
Delay Compensation Bug using destructive punch? | ArKay99 | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-18-2013 03:06 PM |
Punch-in Recording | adiecidue | Pro Tools Express on Mac OS X | 1 | 11-12-2012 10:28 PM |
punch in recording | mastermorris | Tips & Tricks | 2 | 12-02-2005 02:23 PM |
Delay using punch-in? | jwd65 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-06-2005 05:45 AM |
DELAY ON PUNCH INS | MEZZETTI | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-11-2000 12:16 AM |
