Old 07-18-2010, 10:41 PM
nst7 nst7 is offline
Default Re: 88.2 benifits??
That's even more interesting because he mixes analog (last I checked). It makes me curious why he does it. I mean, if it's going to be converted to analog for mixing, why bother?
Old 07-18-2010, 10:50 PM
PTUser NYC PTUser NYC is offline
Originally Posted by loosestones View Post
Just spent 2 weeks mixing with TLA, he dithers everything down to 44.1 before he starts mixing... interesting.
He may well sample convert down to 44.1, but he doesn't dither down. Dither is error correction for word length truncation i.e. change in bits, not rate.
Old 07-19-2010, 01:47 AM
loosestones loosestones is offline
yeah, my bad... that's what I meant to say. His reasoning behind converting down to 44.1 was that it sounded more "rock" and harder in the top end than 48... and yes he's mixing from his tools rig (version 5.x) into his SSL / tape. Whatever sounds good right?
Old 07-19-2010, 07:40 AM
WernerF WernerF is offline
You can't argue with TLA's success story but good god, even the staunchest proponents of higher sample rate benefits admit that there's no sonic difference between 44 and 48 as it's just a couple of bits. Obviously he can believe whatever he wants to believe but we all might benefit by a quick google search of "power of suggestion". And maybe add "smoke and mirrors".
Old 07-20-2010, 04:31 AM
Will Russell's Avatar
Will Russell Will Russell is offline
FWIW- I only record at 96k. I believe 96k has been established as the dvd audio standard. (BTW- the theory that 88.2 is better because the math is easier when converting to 44.1 is fallacious- search for discussions by Nika) I record at 96k because with my 192 I/O there is a clear and obvious improvement in quality. I hear it in transients, depth of field, high frequency detail. To me it is worth the extra cpu load and disk space.
It is my understanding that it is easier and cheaper to make great sounding converters that work at higher sample rates.
Test it your self. If you hear a difference at higher sample rates, then go for it! If you don't hear a difference, then don't worry about it!
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 15.4.1, PT2024.10.2, HDX, S1/Dock
M1 PRO MacBook Pro OS 15.4.1, PT2024.10.2, BabyFacePro FS
  #16
Old 07-20-2010, 05:44 AM
JFreak's Avatar
JFreak JFreak is offline
Yes, you're right, the problem frequencies (18-24kHz) are audible on 48k but inaudible (24-48kHz) on 96k which makes it a whole lot easier to design stuff that should be "perfect".
Perfection as it is means "nobody can hear the difference" and therefore the optimal sampling rate should be 64kHz which would be just as good as 96k but consume 50% less extra CPU cycles and disk space compared to the 48k -> 96k upgrade.
Close to nobody needs 192k, it's all just marketing hype. And not all plugins work with 192k sessions to begin with, and most that do are RTAS only.
Janne
benefits of ram? Cawbaby Pro Tools TDM Systems (Mac) 3 05-18-2008 06:56 AM
mixcore + d24 : having benefits except more I/O ? erikloesch Pro Tools TDM Systems (Mac) 2 06-13-2006 09:24 PM
benefits of more RAM? CrucialRecordings 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-21-2003 11:28 AM
BENEFITS OF MORE RAM? xcrutchstylx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-20-2003 01:06 PM
Benefits? lcouri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-21-2001 07:33 PM
