Pro Tools HD 7.1cs8 Updates
Pro Tools HD 7.1cs8 for Mac OS X & Windows XP
Available for download from the Pro Tools HD 7.1, Pro Tools|HD PCI and PCIe sections in the Support section: http://www.digidesign.com/support In addition to all previous fixes, Pro Tools HD 7.1cs8 for Mac OS X & Windows XP both added the following: Fixed: Some International Characters Were Not Allowed In Pro Tools 7 Sessions (Item # 71269 and 76222) German, Norwegian, Swedish, and French/French Canadian characters were affected. DigiBase search criteria was also affected. Fixed: When Controlling 9-pin Devices with MachineControl, Selections Could Appear on the Timeline When Fast-Winding Pro Tools (Item #75405) This would occur when the Machine Follows Edit Insertion/Scrub preference was enabled. Fixed: Pro Tools Always Overwrites Automation in Existing Playlists When Using "Import (Session Data): Overlay New on Existing Playlists" (Item # 63172) Pro Tools would not allow a session with a 2-hour start time to overlay automation data on a session with a 1 hour start time without clearing all automation before 2 hours on the destination session. - Automation cannot be "combined" with an overlay—the destination session’s automation will be replaced from the Session Start time of the source session. - Inserts and sends must be consistent between sessions or they may be overwritten Fixed: Volume Automation From a Control Surface May Be Inaccurately Written if the System Is Under Load (Item# 75888) This could occur with high track count sessions when using the surround mixer. Fixed: When Controlling a Non-Linear Device with MachineControl in "Transport=Pro Tools," Taking Pro Tools Off Line Would Send a "Stop" Command (Item# 77280) This could stop another 9-pin device in the system unnecessarily. - This change in behavior is activated only by the "Non-Linear Transport Error Suppression" preference. The Following Fix is also included in Pro Tools HD 7.1cs8 for Windows XP Only: Fixed: Scrubbing or Shuttling on a Record-Enabled Track While In QuickPunch could Cause a Reboot (Item #76766) This would occur when a ReWire plug in was being used in the session or when scrubbing on a track with an RTAS plug-in inserted.
Administrator Avid Pro Audio Community |
Pro Tools HD 7.1cs8 Updates | Avid | Pro Tools TDM Systems (Mac) | 39 | 07-26-2006 04:12 AM |
Pro Tools LE & M-Powered 7.1cs8 Updates | GenerationM | General Discussion | 1 | 07-21-2006 07:06 PM |
Pro Tools LE & M-Powered 7.1cs8 Updates | Hype | General Discussion | 0 | 06-21-2006 05:19 PM |
Pro Tools HD 7.1cs8 Updates | Avid | Pro Tools TDM Systems (Win) | 0 | 06-12-2006 02:48 AM |
Pro Tools LE & M-Powered 7.1cs8 Updates | Avid | General | 0 | 06-12-2006 02:24 AM |
