Old 05-06-2005, 12:42 PM
RyanO RyanO is offline
Default PT6.7cs8 Recording Bug - Phantom full disk regions
For anyone it may help...
I've encountered a recording bug in PT6.7cs8 under OS01.3.8 on a G4HD3
If you are recording in quickpunch, when the recording is complete,
immediately following your region will be a "ghost" region that occupies the balance of the time available within the session;
regardless of rec time limits set in the prefs.
On the up side, the region is selectable and deletable.
On the down side, any accidental playback of that area will result in full scale dig noise followed by a kernel panic and the CPU puking its guts out.
The fix, of course, is to not be in quickpunch; and select your target record area.
Haven't tested the prob under 6.9 as yet...
I figured i'd post to help anyone else out that may have been puzzling over the issue.
-r
HTML code is On
Help!! Recording has been terminated because either a disk is full salvatuon Pro Tools 9 6 04-15-2013 09:20 AM
could not complete the bounce to disk command because: a disk is full -34 help? Henrydm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-27-2010 09:07 AM
recording with phantom power *and* without phantom power simultaneously SweetSoulSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-22-2008 07:40 PM
Full blast volume when moving regions Frank Kruse Post - Surround - Video 3 02-12-2007 12:50 PM
Disk full???? gugu Pro Tools TDM Systems (Mac) 5 11-06-1999 01:35 AM
