Re: any good softwere samplers for PT yet?
General sampler ... Kontakt by NI
http://namm.harmony-central.com/WNAM...R/Kontakt.html and for drum samples ... Battery by NI. I haven't used it yet http://namm.harmony-central.com/WNAM...R/Battery.html that's all I can think of at the moment. |
Thanks for the links. SO have you used KOntact? If so, how does it run w/ pt?
besides ssc?
Sorry no.
dabbled with Battery and like what I saw but no time with Kontakt. |
Kontakt is not very good at all imo. If you have a TDM system get the emagic TDM bridge and use the ESX24, If you have an LE system I dont know if its is esb compatible. If it is get it and you can use VST and Logic instruments in PT
Battery is excellent for drums Or get UGLYVSTI which is free (not to sure thats its name), It allows PT to use VST instruments. If it works on your system then you have a multitude of choices. Halion being the best I suspect. Nice interface, very friendly to use. Not as good sounding as the ESX 24 but is multitimbral. Forget sample Cell. Its a cold, bland sounding sampler with a horrible interface. Digi had a good oppurtunity with sample Cell but they blew it. I reckon it is without a doubt the worst soft sampler out there. |
Give me a hint , what is an ESX24 ?? "UGLYVSTI which is free " give me a link here ... I need to experiment with this. "Forget sample Cell. " Ouch! [img]images/icons/shocked.gif[/img] I do understand this sentiment. Sample Cell is not up to the user standard of some of the others. BUT it is still reliable in out PT systems. This part is dificult to explain as it has so many aspects and history. ProTools is your chosen host software and then to that you add plug-ins and soft stuff and even some Hardware bits. It's all money. Then comes the up-grades and ineviatable changes to code etc. OS and Computers and protocols all change and when they do your Plug or soft purchase stops working and you may have to up-grade.... more money. I guess the point I am making is staying close to the Digi product can help here. Also when ever you have a very important part within a song "print it to the HD as audio".... so if that piece of S/W goes AWAL you still have the part. I have many a software that now cannot be run in my current system. Even the Freebies so don't get too attached to the freebies as they may stop working when you up-grade. good luck and experiment before spending the cash. |
Anybody have experience with these vst wrappers and Halion. Im just switching over to ProToolsLE w/Mbox setup. Would like to be able to use Halion on my Mac if I can.
Thanks |
I have been using Battery with my MBox (on an iBook)
Results have been satisfactory www.iBookStudio.com (if you want to hear them) and I would be happy to help anyone in a similar set-up (there were many phone calls made to tech support at both Digidesign and Native Instruments to set it up) |
Are you using Battery in PTLE 5.3.1 on XP?
Steve Moore
Cast of Characters Audio San Antonio, Texas |
Good drum synths/samplers for use with PT6.4 | SixChurchStreet | Virtual Instruments | 17 | 04-24-2007 10:29 AM |
OT: free softwere for cd cover print and design | ariel keshet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-19-2005 08:29 AM |
sample tank bundeled softwere - problem | ariel keshet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-11-2005 09:41 AM |
Good Drum Samplers? | tim carter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-04-2005 07:15 AM |
Best translator for samplers to samplers libraries? | maxserg | Pro Tools TDM Systems (Mac) | 12 | 09-20-2002 04:54 PM |
