Old 05-13-2021, 07:15 AM
humpback humpback is offline
Default Method to import track names?
Hi all, thought I'd tap the collective hive mind and see what pops up! I need to streamline - if possible - naming tracks. I have 1000 tracks to name, that correspond to names from an Excel SS. Is there a way to essentially import the Excel data such that each name gets its own track, rather than input each name manually? Note: I am not naming clips within a single track. I'm thinking perhaps some Post folks may have a solution, if there is one.
Thanks in advance for you help!
Studio:
Mac Mini 2.6 GHz i7
16GB RAM
PT 2019 and 10.14
UA Apollo Quad
Outboard:
2 x Summit Audio 2BA-221>TLA 50>EQF-100
2 x dbx 165a
4
x Shadow Hills GAMA
http://humpbackmedia.net[/SIZE]
Old 05-13-2021, 07:54 AM
its2loud its2loud is offline
Default Re: Method to import track names?
If the names in your spreadsheet are sequential in order but carry the same base name you could use Batch Track Renaming. This allows some customization of the track names in.
If each track has a different name all together this might prove more difficult. EdiLoad or EdiMarker might have this capability but I’ve never used it for track naming, only for markers from Excel.
https://www.soundsinsync.com/products/ediload
If there was a way to generate an AAF from your SS, Pro Tools could import the session data from the AAF and generate new tracks from the session import retaining the track names.
Old 05-13-2021, 08:13 AM
Thanks its2loud! Ugh. Kind of thought there'd be this issue. The names are not sequential; each name is unique. I'll look more into the creating an AAF. I have EdiMarker, but so far have not been able to make this particular workflow happen with it so far.
Studio:
Mac Mini 2.6 GHz i7
16GB RAM
PT 2019 and 10.14
UA Apollo Quad
Outboard:
2 x dbx 165a
4
x Shadow Hills GAMA
AAF import after track names disappear [SOLVED] bohitomi Post - Surround - Video 11 01-26-2018 07:33 AM
OMF/AAF export/import - track names Mringlesworth Post - Surround - Video 0 06-19-2014 10:44 AM
Track names vs Playlist names bredo Pro Tools 10 6 01-07-2013 08:29 AM
Looking for help confirming my track bouncing method queenstonmusic General Discussion 2 09-26-2010 07:04 PM
Unsexy feat. request #2 - Import session data & track names Starcrash Post - Surround - Video 2 03-18-2007 09:04 PM
