PT 2022.10 crashes with buffer change
MacBook Pro 2020 -11.7 Big Sur- UA Arrow interface-PT 2022.10 Studio
Rather light session 8 audio tracks and very few plug ins. Granted it was 45 minutes of full audio across 8 channels. I change buffer from 128 to 64 and I get the spinning beachball of death. Twice it happened and the 2nd time it crashed Avid Crash manager popped up and I send the report to Avid. |
Re: PT 2022.10 crashes with buffer change
Must be an issue with the longer audio files because when I do the same buffer size change on a session with more audio tracks-30- but less than 4 minutes of music I have no issues at all
Or a problematic or corrupted session? What happens after you try a Save Session In for the problematic session? And what happens with doing this in both sessions when you use Built-In Output/Speakers or whatever as the playback engine?
How much free space on your recording drive?
I will try importing the wave files into a new session. No issues saving that session.
Looks like the issue was the session was corrupted. I switched playback engine to MacBook Speaker output, created a new session and imported session data. Thought I would try the import data before importing wavs. New session had no issue changing the buffer to 64. I switched playback engine to the UA Arrow and no issues changing the buffer to 64 then higher and back to 64.
The original session was created on 2022.6. was originally recorded on a Lynx 16 with the USB2 card. I have had corrupted sessions before those behaved much differently. I will have to keep that in mind. Thanks for the suggestion Darryl! |
Hey neat that worked. With plugins involved in saving the session file I'm surprised we don't see more issues... and I have a theory that session file corruption/incompatibility may cause weird problems more than we think.
Nugen Mastercheck Crashes 2022.9 | bernstudios | Pro Tools | 11 | 10-11-2022 10:57 AM |
Can't change Default Output Bus in 2022.7 [PT-290371] | simonchase | Pro Tools | 13 | 09-28-2022 12:23 PM |
AAF import crashes PT 2022.4.0 | Jazzbass56 | Pro Tools | 3 | 05-03-2022 08:10 AM |
Can't change buffer size, It is stuck in 512 and 1024. How can I do to change it? | Ariel Chimba | Pro Tools 12 | 9 | 12-23-2017 11:17 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
