Old 11-05-2024, 10:07 PM
Ptbright Ptbright is offline
Default Licensing plugins - how to rescan
Hello all,
I had a few plugins that I did not have licenses for, and when starting up pro tools I checked the box telling pt not to look for these plugins anymore. As such they don’t show up in the list of available plugins.
The plugins are installed and are visible in the plugins folder. How can I get pt to rescan these/load them when starting?
Thanks
Old 11-05-2024, 11:17 PM
Default Re: Licensing plugins - how to rescan
They were moved by Pro Tools from the plugins folder /Library/Applications Support/Avid/Audio/Plug-Ins to the "unused" folder /Library/Applications Support/Avid/Audio/Plug-Ins (Unused).
You can just manually move those .aaxplugin bundles back to the Plug-Ins directory and start Pro Tools.
Old 11-06-2024, 02:01 AM
Thanks Darryl. I checked and the plugins I’m looking for are in the plugin folder. The unused plugin folder is empty which is surprising me.
Old 11-06-2024, 04:22 AM
junkgear's Avatar
junkgear junkgear is offline
You can try deleting the cache file for the plugin. Cache files are located in ‘ Users/Shared/Pro Tools/AAXPlugInCache’ and each plugin will have its own file. Delete the ones for the plugins you need rescanned, then start Pro Tools.
Will
System Details
Old 11-06-2024, 06:09 AM
tope d's Avatar
tope d tope d is offline
Originally Posted by junkgear View Post
You can try deleting the cache file for the plugin. Cache files are located in ‘ Users/Shared/Pro Tools/AAXPlugInCache’ and each plugin will have its own file. Delete the ones for the plugins you need rescanned, then star Pro Tools.
+1 on this
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Waves Plugins Rescan - SAME SSD - New Chassis thedevillokius AAX Plug-ins 9 03-05-2024 02:34 AM
Rescan Plugins ggw2015 Pro Tools 4 05-02-2023 09:52 AM
Rescan plugins within protools 12 mac question firmflange Pro Tools 12 1 12-11-2015 09:15 PM
Is it possible to rescan plugins? drorsh4 Pro Tools 9 6 07-28-2011 01:38 PM
Licensing Plugins help? nemisis63 General Discussion 1 10-25-2002 03:58 PM
