Old 11-04-2024, 07:01 PM
Sparky1 Sparky1 is offline
Default Playlists Not Showing All Tracks Unless...
Hi there.
I can't figure out why this has happened to my playlists...
After changing from "waveform" to "playlists" - then using the drop down by the name of the track - I don't automatically see all my my playlist tracks.
I did discover that from that same drop-down by the track name - and under "Target Playlist" - there is an option to select "other playlists" - which has all my other takes.
Once I select from this list - it will appear in my list of takes when I select "Playlists" instead of "Waveform"
Currently - I would need to individually select each take - so that they will reappear in may "playlists" view - of all the takes...
I hope this makes sense - as I'm just trying to see all the takes on that track...
Is there a setting I somehow changed or need to change?
Thanks,
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.4.1
Old 11-06-2024, 03:34 AM
frederic Bacquet frederic Bacquet is offline
Default Re: Playlists Not Showing All Tracks Unless...
Hello,
I've got the same issue....
Old 11-06-2024, 04:07 AM
EmilILönneberga EmilILönneberga is offline
Originally Posted by Sparky1 View Post
Hi there.
Thanks,
Sparky
Usually other playlists would refer to playlists from different tracks in the same session. You sure, you're on the right track? (No pun intended)
Old 11-06-2024, 05:42 AM
Yeah… though not sure how I couldn’t be… since I can see the other takes by accessing the “other playlists” area
It almost seems that the other takes from that track have somehow become disassociated with the original track… and need to be reactivated or re-recognized…
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.4.1
Old 11-06-2024, 06:59 AM
Do you have any other tracks containing playlists in your session? What happens if you duplicate the track (inlcuding playlists)
Old 11-06-2024, 07:00 AM
tope d's Avatar
tope d tope d is online now
Have you tried opening 2024.6? is the same happening?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 11-06-2024, 02:35 PM
I just opened the session and checked out a different track - it behaves the same.
Interestingly - I noticed that both of these "other playlists" options opens up a long list of all play-listed tracks from all tracks. For example - my guitar "other playlist" lets me select takes from my vocal track.
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.4.1
Old 11-06-2024, 02:40 PM
Hi tope d
Yes - the same behaviour... weird...
Everything else seems to work well...
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.4.1
Old 11-06-2024, 03:01 PM
Sparky
That's normal behavior.
Via 'other playlists' you can select takes from (wait for it) other playlists. Like you said, if you have a guitar track with several playlists and a vocal track with also several playlists, you can select any of your guitar playlists and add it to your vocal playlists (and vice versa). This only works if the track your taking the playlist from isn't in playlist view, otherwise you'll get this error:
Could not complete your request because the playlist xxx.11 is associated with another track. It must be restored to its original track before switching the playlist group..
Old 11-06-2024, 04:25 PM
I just tried importing the data into a new session - with the same results...
Sparky
Pro Tools 2024.10
Avid Carbon
Ventura 13.4.1
Playlists Grouped Between Tracks? anackman Pro Tools 12 4 08-26-2015 11:38 AM
moving tracks into playlists? chrisosaki Pro Tools 10 3 07-24-2015 05:47 PM
Change all Playlists to Tracks clusterer Post - Surround - Video 4 07-14-2010 01:43 AM
Comp tracks [composite tracks] from playlists ??? gollywillickers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-08-2005 08:01 PM
using playlists from several tracks!! Rifpop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2005 11:00 PM
