Drag and Drop into AAX Samplers
Hey everyone, I'm new here and a recent Pro Tools convert after years of Logic and Ableton. I'm loving Pro Tools a lot so far and digging the powerful workflow improvements. You already know that each DAW has it's pros and cons, there is no perfect DAW. But Pro Tools comes really close for me.
One thing I simply can't get over as a composer/producer is the lack of Drag and Drop functionality in PT. No other DAW has this problem. Fumbling through various Finder menus to find a collection of samples to throw into Kontakt vs simply grabbing a kick, hat and snare from the workspace and dragging them right in is an infinite difference in time and effort. Please Avid, on behalf of every producer/composer, fix AAX protocol once and for all and allow this invaluable functionality just like every other DAW on planet Earth. |
Re: Drag and Drop into AAX Samplers
I completely agree!
Back when Pro Tools used RTAS, Drag and Drop functionality was there. But with the switch to AAX, we lost it for some reason. I don't understand the technical reasons why it can't be added back, but my understanding (which I hope someone chimes in and tells me I'm wrong) is that it is a limitation of AAX which means that if this functionality ever comes back, all plug-in developers will have to code to a new format. But over the years, this one really really bothers me and it is so uninspiring to have to export audio files and then navigate to them from the instrument's browsers.
Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Yes, I want to be able to drag a clip from the timeline into a plugin window. They show that in the Waves CR8 video, but the drag and drop feature doesn't work on PT, it ends up moving the clip. So I have to export the clip as a file, then import it back in through Waves which is slower. I'd love to see the drag and drop fixed.
It used to work with STRUCTURE (AIR Music Tech) in the RTAS days.
I am missing it badly, besides I spent money for having exactly this function in PT Now I have a VI that has become useless, at least for me!
------------------------------ walter-rohrbach.com |
hey OP they made it real lol
I'm amazed it took so long but thrilled that it's finally here.
and it made me re-discover Structure Free, which is really most of what I need in a quick-n-dirty in-Session Drag-and-Drop sampler.
Kerry Smith http://apothekerry.com Mac Studio M1 Ultra : 128GB RAM : Ventura 13.6.8 : Carbon : PT Ultimate 2024.10 : S1 : Metagrid Pro |
At one point we had to slice up each section in PT, save that as an individual file, go to Kontakt and import each one, place them on the keyboard and set their pitch. |
Maschine - anyone try drag and drop to this? When I drag audio from the timeline, it creates a "Sampler" in the slot and appears to be importing... but the result is blank audio (but the right time length). Two steps forward... one back. But this would be awesome for Maschine.
Check your hardware Make sure your hardware is connected, turned on, and turned up. You can also try getting audio from another software program, like a web browser. Check your playback engine Make sure your interface is set as the playback engine in Pro Tools. You can find the I/O Setup window under the Setup menu. Route MASCHINE's audio Load MASCHINE in an Instrument Track in Pro Tools, then create a new Audio Track. Send MASCHINE's audio to Bus 1-2, and set the Audio Track to receive audio from Bus 1-2. Turn off Auto Low Latency In the Delay Compensation section of the Audio Track, right-click on the cmp indicator and select Auto Low Latency off.
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
MIDI drag and drop causes instrument track to drop channel | midnightrambler | Pro Tools 2018 | 6 | 06-15-2018 11:01 AM |
Trouble drag&drop files - I don't get what I drag in | Sir Hannes | Post - Surround - Video | 3 | 12-10-2017 08:39 AM |
Drag and drop | Ophir_Lokay | Tips & Tricks | 0 | 12-26-2013 05:29 AM |
Drop and Drag | justeve | Pro Tools M-Powered (Win) | 0 | 08-17-2010 01:42 AM |
can´t drag /drag and drop from DigiBase in 7 | jofromabove | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-28-2005 09:04 AM |
